Enthusiast ![]() ![]() ![]() Joined Sep 6, '03 From hudson ,iowa Currently Offline Reputation: 1 (100%) ![]() |
thats the only plug that doesnt have a home, the harness was done by dr. tweaks business, its single gray plug with only one wire and its located between the firewall and the starter, it has no home that i saw , i must have missed something, mayeb this is why my injector wont fire , lol[img=http://img23.imageshack.us/img23/6208/randomplug.th.jpg]
This post has been edited by pxcr440: Mar 1, 2010 - 5:29 PM |
cold start injector maybe? look under the throtle body?
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) ![]() |
what shape is it? won't fire huh?
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
CSI has 2 wires going to the plug, but it wont extend that far to the starter. It has a square plug anyway, and IIRC black and green wire.
The grey plug could deal with the coolant temp sensor. Do you have everything hooked up on the coolant out let neck? -------------------- 98 Celica gt red- totaled deer
dare i ask but its not the plug for the main relay?
and if you get a second can you check out my thread? i'm looking for details on fuel lines routes. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
post a picture of it.
Are all of the sensors on the coolant plugged in already?
the two are connected on the front , along with the one in the head on the same set of plugs, there is a one flat spaded sensor on the back of coolant neck, but thats for a simple black flat spade connector withc this isnt , the plug has 12 volts at key one and duriing cranking
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
knock sensr?
or oxygen sensor... -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) ![]() |
knock knock... whos there?
however your car will still run with that unplugged... search more for the true problem all your injectors won't fire? will it crank? injectors won't fire if the AFM is not hooked up This post has been edited by pittfirefighter: Mar 2, 2010 - 1:38 PM -------------------- Breaking Axles...
Enthusiast ![]() Joined Jan 28, '07 From Québec, Canada Currently Offline Reputation: 1 (100%) ![]() |
x2
Knock sensor plug Verify that you have +12V at all your injectors, coil, igniter. Check all your grounds (near battery, under intake manifold, etc.) Sam |
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) ![]() |
Def the knock sensor.....X3
-------------------- (\__/)
yep now that i see the pic, knock sensor
Lo-Fi Version | Time is now: February 20th, 2025 - 6:31 AM |
