> Paint, Need advice for painting center console
post Mar 2, 2010 - 2:34 PM
Dangercart1
Joined Dec 8, '09
Im trying to paint the plastic part that goes around the radio and climate box, any suggestions on types of paint? Or any thing else that would help out? I would appreciate it thanks
I'll be sure to post pics when I'm done.
This post has been edited by Dangercart1: Mar 2, 2010 - 2:35 PM
post Mar 2, 2010 - 3:06 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
yuo gonnna keep the stock texture or you want it smooth? simple dishwashing soap to clean the surface, primer and paint (for plastics) should do.
how good are you with the rattle can? Can you get smooth even sprays with your passes? Always paint in a cool dry non-dusty environment.
post Mar 2, 2010 - 3:54 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Don't forget to let the paint cure! If you start reinstalling it after only a day or two to cure, expect chips and such.
post Mar 2, 2010 - 5:34 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
"Don't forget to let the paint cure! If you start reinstalling it after only a day or two to cure, expect chips and such."
Big tip! You could do everyhting correct with the painting stages, but if you don't let the paint cure correctly, it could mean having to start all over again.
post Mar 4, 2010 - 8:05 AM
Dangercart1
Joined Dec 8, '09
thanks a lot everyone these tips are very helpful
post Mar 5, 2010 - 4:16 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Dangercart1 @ Mar 4, 2010 - 3:05 AM) *
Uhhh you didnt answer any of my questions..........
post Mar 5, 2010 - 4:14 PM
zoik
Joined Aug 28, '07
From france
tip: paint with a wet floor, while moving you wont move dust (well, just the one ine the air,ie not much)
This post has been edited by zoik: Mar 5, 2010 - 4:14 PM
post Mar 5, 2010 - 5:26 PM
mgnt232
Joined Mar 16, '09
Personally, everyone says you have to prime and stuff. But I painted the whole (pic) interior of my car, with krylon for plastics (bought anywhere) and as long as you clean the surface of all the dust and dirt, you only have to paint.
READ! the back of the can, and do exactly as it says, and TIME everything! to exactly what the can says and it will turn out like mine
QUOTE (Dangercart1 @ Mar 2, 2010 - 2:34 PM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Mar 5, 2010 - 6:32 PM
rave2n
Joined May 29, '09
Yea, it'll look like your does. Doesn't mean the paint will stick for the longevity of the paint.
Primer is to create a surface for the paint to adhere to.
You can do it cheaply, or you can do it right....simplicity has its costs.
post Mar 5, 2010 - 6:58 PM
mgnt232
Joined Mar 16, '09
Mines been done for over a year, and it still has the same color and everything.
As long as you dont treat your celi like a all terrain truck the paint will not chip or fade.
just how mine is and has been.
QUOTE (rave2n @ Mar 5, 2010 - 6:32 PM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
Lo-Fi Version Time is now: January 14th, 2025 - 5:22 AM
