95/96 engine... |
95/96 engine... |
Mar 18, 2010 - 8:02 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
tried searching but since the search doesn't allow for two character searching....i have a 96 chasis and the 95 motors are cheaper to replace...what i know that i need to switch over= EGR, Dizzy, and i think the coolant housing with the sensors...anything else did i overlook?
thanks guys -------------------- |
Mar 20, 2010 - 9:50 AM |
Enthusiast Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
94-95 Has OBDI
96-99 Has OBDII add diagnosis sensors and computers to that list. -------------------- |
Mar 21, 2010 - 7:50 AM |
Enthusiast Joined Sep 6, '09 From California Currently Offline Reputation: 0 (0%) |
tried searching but since the search doesn't allow for two character searching....i have a 96 chasis and the 95 motors are cheaper to replace...what i know that i need to switch over= EGR, Dizzy, and i think the coolant housing with the sensors...anything else did i overlook? thanks guys You'll need to reuse your 96 complete intake manifold and exhaust manifold to keep it OBD2. Because all the OBD2 emissions equipment you want to keep. |
Mar 21, 2010 - 9:08 AM |
aint there a difference in the block, there is a sensor in the 97 that 95 does not have..
Mar 21, 2010 - 9:14 AM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
aint there a difference in the block, there is a sensor in the 97 that 95 does not have.. i think it is the crank angle sensor.......... or some crankshaft related sensor there that the obdII has that obdI does not. -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Mar 21, 2010 - 9:36 AM |
the 96+ have the crank sensor intergrated into the oil pump housing, and the trigger wheel for it is intergrated into the crankshaft t-belt pully.
you will need to swap those over, along with the distributor, ect. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Mar 21, 2010 - 2:46 PM |
the 96+ have the crank sensor intergrated into the oil pump housing, and the trigger wheel for it is intergrated into the crankshaft t-belt pully. you will need to swap those over, along with the distributor, ect. Good point. I thought when he said dizzy i thought he knew to swap all obd2 sensors over. Because if those sensor isnt in there he'll be throwing CEL. In a sense putting in an obd1 motor could be a task. I'd recommended just putting in same year motor or newer. This post has been edited by ZC_6Gen: Mar 21, 2010 - 2:48 PM |
Mar 23, 2010 - 11:01 PM |
ya i was debating about the crank angle sensor as well. thanks for all the input guys...there is like a 500 dollar difference in motor pricing...that's why. i can get the obd1 motor for 450 bucks where they want over a g for the 96 and up one
Lo-Fi Version | Time is now: December 3rd, 2024 - 7:54 PM |
