![]() Enthusiast ![]() Joined Aug 1, '03 From Holland, MI Currently Offline Reputation: 0 (0%) ![]() |
Hey, does anyone know how i can change the color of the leds in the center column of the car?
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
heater control lights That should give you a head start...... I hope you're good at soldering
defgeph This post has been edited by defgeph: Nov 10, 2003 - 8:40 PM -------------------- ![]() I will return one day. |
![]() Enthusiast ![]() ![]() Joined Apr 19, '03 From Washington Currently Offline Reputation: 0 (0%) ![]() |
looks good...but how do you actually get the heater/cooling control unit out...i tried but it didn't work
you have follow the two cables back One black cable one blue cable........one cable ends inside the car to the left of the gas pedal and the other goes outside through the fire wall....... just disconnect the two cables and pull the control box out defgeph -------------------- ![]() I will return one day. |
![]() Enthusiast ![]() Joined Feb 17, '03 From Adelaide, South Australia Currently Offline Reputation: 0 (0%) ![]() |
hey defgeph,
how did you manage to change the clock to red? |
I took the clock apart and just taped some red subject tabs to the inside of the clock I tryed lense repair tape but that didnt work defgeph -------------------- ![]() I will return one day. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) ![]() |
This may be a dumb question but what are red subject tabs?
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
they are the subject dividers w/ the colors that you slip a piece of paper in to tell you whats in that subject
you are correct sir !! -------------------- ![]() I will return one day. |
ok when i disconnect those wires...are they easy to put back??
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:02 AM |
