4th gen caldina turbo limits, how far can i go with this turbo? |
May 6, 2010 - 8:32 AM |
Enthusiast Joined May 5, '10 From netherlands Currently Offline Reputation: 0 (0%) |
hello there,
i'm new on this forum and think it's great tried to find info about caldina 4th gen 3s-gte i want to know how far i can go with the original caldina turbo because it kicks in at low rpm (1.1 bar at 2800rpm) it drives very good on the road Visit My Website got a fmic and 3"exhaust but after 4000rpm the pressure drops from 1.1 to 0.9 or even 0.8 bar at 6000 rpm aem boostcontroller set at 1.1 bar , walbro fuelpump (look at proflie for info) 280 hp is the max at this moment thanks |
May 6, 2010 - 3:45 PM |
Enthusiast Joined Sep 22, '08 From Bergenfield Currently Offline Reputation: 5 (78%) |
Add a helper spring, and it will allow you to run higher boost pressures, AND hold it to redline.
Here is the how to I wrote up: Click Me --------------------
May 7, 2010 - 5:11 AM |
isn't that the same as filling up with washers underneath the wastegate mount?
i took a electronic controller so i didn't have to do that i did that with a mk3 supra turbo can try the spring option you know what the max is of the caldina turbo? i know the engine is strong but can't find much about the turbo This post has been edited by evert1976: May 7, 2010 - 5:13 AM |
May 7, 2010 - 11:29 AM |
Enthusiast Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
why did you choose a 4th gen over a 3rd gen 3sgte?
May 7, 2010 - 1:25 PM |
Enthusiast Joined Aug 13, '07 From Arizona Currently Offline Reputation: 1 (100%) |
Great job on the swap I want to try the same thing sumtime in the future I hope. Was it hard to swap it in? did u have alot of bugs to work out? Was there any additional steps that needed to be taken because this swap was a st215 engine not the st205 engine? FWD?
May 7, 2010 - 1:40 PM |
friend of mine had one and it whas more powerful then the 3th gen
and turbo is much more alive in the low revs perfect for street use later i heard that the block is also stronger build then the 3th gen friend of my did the wiring including the jdm climate controle the rest is the same is every 3sge or gte already had the superstrut and turbo gearbox with LSD as a factory option so that whas an easy one fmic and 3"exhaust is all home made axles stayd the same also. forgot to tel its fwd had good grip with the toyo tyres now ivé got hankook and it spins even on dry road if i drive "normal" so it wil be toyo's again soon This post has been edited by evert1976: May 7, 2010 - 1:44 PM |
May 9, 2010 - 9:01 PM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
you can look towards the ball park of around 330 hp about 20lbs of boost for that turbo/motor, after that upgrades are necessary its a very good motor and damn near identical to the 3rd gen... (with the exception of some things)
This post has been edited by easternpiro1: May 9, 2010 - 9:10 PM -------------------- |
May 10, 2010 - 4:19 AM |
ok thanks,
what can it be that he wil stay at 280 ? 3'' exhaust , fmic with 2,5"piping maybe the intercooler is not up for the job? it a truck intercooler cut in half with new sides on it. if i can get 330 i'll be very happy wil not go for new mods cause i've also got a 2JZ in a bmw E30 chassis to build but another intercooler is not that expensive and an easy fix if so... |
May 13, 2010 - 3:27 PM |
ok thanks, what can it be that he wil stay at 280 ? 3'' exhaust , fmic with 2,5"piping maybe the intercooler is not up for the job? it a truck intercooler cut in half with new sides on it. if i can get 330 i'll be very happy wil not go for new mods cause i've also got a 2JZ in a bmw E30 chassis to build but another intercooler is not that expensive and an easy fix if so... you will need some good tuning for the power goals you want. I had a FMIC and 3inch downpipe-exhaust and got almost 270 by just that. i didnt up the boost or anything. this was on stock boost (15psi) -------------------- |
May 14, 2010 - 2:51 PM |
Enthusiast Joined Oct 30, '08 From Geldrop Netherlands Currently Offline Reputation: 5 (100%) |
on 16,5psi I got 301.7hp & 269.4whp.
full 3" exhaust, FMIC with 2,5" piping This post has been edited by marcov: May 14, 2010 - 2:51 PM |
May 17, 2010 - 8:22 PM |
on 16,5psi I got 301.7hp & 269.4whp. full 3" exhaust, FMIC with 2,5" piping on a stock 4th gen you got that?!? at just 16psi?!! -------------------- |
May 18, 2010 - 2:48 AM |
20 hp diff but on another dyno
E. |
May 18, 2010 - 1:47 PM |
oh? what dyno? do u have a chart?
May 18, 2010 - 2:27 PM |
May 19, 2010 - 10:20 PM |
WIN. ^^^^^^^
May 20, 2010 - 7:41 PM |
Enthusiast Joined May 15, '10 From pinole Currently Offline Reputation: 0 (0%) |
this dyno on the stock turbo.cool
Lo-Fi Version | Time is now: January 9th, 2025 - 2:29 PM |
