Enthusiast Joined Jun 4, '03 From chitown Currently Offline Reputation: 0 (0%) ![]() |
The car is an auto 96 st hatch. It has an alarm with keyless entry. There is an open 3rd channel output from the alarm that I can use for a remote start. Can someone please give the color coding or wiring diagram and location for the following:
Constant 12V Accessory Starter/Crank Ignition #1 Ignition #2(if there is #2) Break input Thanks. |
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) ![]() |
When i installed my autostart, they told me to go to a website that tells u what wires are what . What kind of autostart did u get? I think mine was a bulldog or some crap... For the brake light, i looked in my tails for what wire was going to the brake, then found that wire in plastic thing under the door, hooked up a voltometer or whatever the hell its called, and hit the brakes, got 12v, so all gravy... Maybe that helps? If you want i can try to find the site...
-Ryan -------------------- AIM : FAQdaWorld
Wham
BAM thank you mam......... BTW... dont ever go to bulldog.com.... yuck!!!!!!!!!! www.bulldogsecurity.com is GOOD Thats the diagram you need for it... -------------------- AIM : FAQdaWorld
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
In addition, the brake wire can be found in the driver's kick panel. I could tell you which wire it is exactly and take a photo, but I don't have my car.
![]() Enthusiast ![]() ![]() Joined Mar 31, '03 From Bowling Green, KY Currently Offline Reputation: 0 (0%) ![]() |
there are two wires on the brake harness above the brake pedal, use voltmeter/test light to see which on has +12v when depressed. Also these are all the wire colors for my car:
Constant 12V-i dont have this one written down, my remote start gave me 8ga wire to connect to battery Accessory-gray Starter/Crank-blk/white Ignition #1-blue/red Ignition #2(if there is #2)-blk/orange |
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:17 PM |
