> help please, my car died
post May 21, 2010 - 2:38 AM
Johnnyny
Joined Apr 28, '09
From York pa
Not sure wat happened I made a turn into my work no bumb or nothing amd my tires lost power my engine still runs fine and my tranny but iwhener I try. To move the car it grinds not the tranny I'm thinking the axle maybe not sure too dark to try and look. frown.gif any ideas axle maybe idk
post May 21, 2010 - 2:42 AM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (Johnnyny @ May 21, 2010 - 3:38 AM) *
The grinding sound is coming from the ddrivers side
post May 21, 2010 - 4:53 AM
popped axle, when was the last time the tranny oil got changed or measured.
post May 21, 2010 - 5:06 AM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (njccmd2002 @ May 21, 2010 - 5:53 AM) *
Not sure when it was changed so it was in my to do list but money has been tight.... great popped axle I'm screwed
post May 21, 2010 - 5:53 AM
yarik83
Joined Nov 22, '04
From FL
if you hurt 1 axle then other one should still have power to it. If neither of your front wheels even attempts to spin I think your problem is not an axle. I am thinking you may have an issue with torque converter or transmission.
I assume your car revs up but nothing happens right?
Captain Pessimist
post May 21, 2010 - 6:01 AM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (yarik83 @ May 21, 2010 - 6:53 AM) *
Yes it revs but. It kinda jerks like it wants to move but can't neither tire moves
post May 21, 2010 - 9:13 AM
Johnnyny
Joined Apr 28, '09
From York pa
finally got underneath and it is the axle lame....
post May 21, 2010 - 9:14 AM
azian_advanced
Joined Apr 18, '05
From Calgary
if your axle broke, the other wheel isn't going to pull.
it could be that your cv joint broke.
or your clutch is done for.
post May 21, 2010 - 12:25 PM
are you auto or manual
post May 21, 2010 - 1:13 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (njccmd2002 @ May 21, 2010 - 1:25 PM) *
manual of course and its either a cv joint or the axle thanx for the help guys i would try to fix it myself but no proper tools mechanic wont get to work on it till monday....
post May 21, 2010 - 1:27 PM
rave2n
Joined May 29, '09
From Gainesville, FL
They pretty easy to put in, only odd tool you need is for the axle nut. Rest is stardard sockets, and a pry bar. Oh and the fluid to refill the trans =P
post May 21, 2010 - 1:41 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (rave2n @ May 21, 2010 - 2:27 PM) *
sounds easy but im currently lacking the confidence.... to do so even though i should put the chiltons that i just got to good use but on the other hand its more expensive to tow it home than what im paying... mechanic is a block away from work
post May 21, 2010 - 2:33 PM
rave2n
Joined May 29, '09
QUOTE (Johnnyny @ May 21, 2010 - 2:41 PM) *
Ah, not a bad deal then. Did my passenger not to long ago, only part that really sucked was the boot was blown and grease was everywhere =/
post May 21, 2010 - 3:19 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (rave2n @ May 21, 2010 - 3:33 PM) *
ahh sux sorry to hear dat. well at least today hasnt been all bad finally got some good news....
Lo-Fi Version Time is now: February 17th, 2025 - 1:28 AM
