> hic-up
post Jun 1, 2010 - 4:28 PM
6gc_ct
Joined Apr 5, '10
From conneticut
hello everyone,
I have a question about my car. Cant seem to find anything. But while at idle and holding the gas slightly, accelerating slowly, it seems as if it cuts out of fuel once it hits 2k, it will go back down to normal idle rpm then will increase again (still holding down the gas) and obviously it repeats itself.
I am throwing a code 25 (afr lean) and i have a hunch this might have something to do with it. any help and thought is appreciated, thank you
post Jun 2, 2010 - 3:30 PM
6gc_ct
Joined Apr 5, '10
From conneticut
nice
post Jun 2, 2010 - 4:03 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
QUOTE (6gc_ct @ Jun 2, 2010 - 1:30 PM) *
nice
What's that, some passive aggressive way of saying "uh, hello?" or "help, PLEASE" ? A simple "bump" would suffice.
There are quite a few things that can cause this problem you're experiencing. You could have a vacuum leak to the intake manifold; could be an EGR problem, or your IAC. Check all your vacuum hoses and make sure they're connected properly, not split, cracking/cracked, bulging, or otherwise compromised. Clean your IAC valve. Clean the whole throttle body for that matter. Then see what happens.
post Jun 3, 2010 - 4:50 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
QUOTE (GriffGirl @ Jun 2, 2010 - 10:03 PM) *
nice
First of all...LOL
Second, I agree.
post Jun 3, 2010 - 5:42 PM
6gc_ct
Joined Apr 5, '10
From conneticut
yeah...i apologize guys, just had a really horrible day yesterday. sorry. will look into it though. thank you
post Jun 3, 2010 - 6:15 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
QUOTE (6gc_ct @ Jun 4, 2010 - 1:42 PM) *
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post Jun 3, 2010 - 9:03 PM
6gc_ct
Joined Apr 5, '10
From conneticut
tried some stuff out, the surging was a mis-adjusted TPS no biggy. but still running lean, it might be my IACV but not sure. but one thing that i noticed is that i dont have the cold start function, it goes straint to low idle. and i have cleaned the valve already so that can be ruled out.
post Jun 3, 2010 - 9:15 PM
Bigblock
Joined Feb 14, '09
From Mid West
Just goning to toss in 2cents...
fuel filter been replaced? Pump maintaining pressure?
Does it " buck " like a noob learning to drive a stick??
post Jun 3, 2010 - 9:50 PM
6gc_ct
Joined Apr 5, '10
From conneticut
fuel filter recently replaced, and no it doesnt. drives like it normally would. it probably is something really stupid. but because its lean it can be a number of things thumbsdown.gif
post Jun 3, 2010 - 11:29 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
You could try an in-line fuel injector cleaner. The type you remove a vacuum hose and feed into the engine while its running. Very possible you have 1 or more plugged injectors.
post Jun 4, 2010 - 1:13 PM
GriffGirl
Joined Feb 7, '07
QUOTE (Jamchell @ Jun 3, 2010 - 9:29 PM) *
This is a really good idea, actually. It might not solve the problem, but it'll certainly help to eliminate potential causes, and you only stand to benefit from it. A lot of people on here have used Seafoam (it's a brand, not actual stuff from the ocean laugh.gif ) and I also highly recommend it. You can get it at most auto parts stores, Autozone, Oreilley's, etc. Fill up a CLEAN empty Gatorade Sport bottle or water bottle (the kind where the top pops up, not the kind w/the cap that unscrews) about halfway w/Seafoam, and cut the pop up top enough so you can fit a vacuum hose in. You can use your brake booster line. With the engine running, suck up the Seafoam, and don't be alarmed when all sorts of smoke pours out of your exhaust, and the engine stalls. This is normal.
Also, and I know this sounds kinda lame, but I actually had a very similar problem when I first got my Celica like 2+ years ago. I did everything to try to figure out what the heck was wrong with it, and it turned out to be the most obvious thing that of course I overlooked by overthinking it - I just needed new spark plug wires. When did you replace yours last? A basic tune up is ALWAYS beneficial as well as helps to further narrow down the possible culprit.
post Jun 4, 2010 - 4:08 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
AFR lean - did you check your o2 sensor?? if its getting wrong readings, it will screw up your idle
Breaking Axles...
post Jun 4, 2010 - 4:21 PM
6gc_ct
Joined Apr 5, '10
From conneticut
last tune up was about 3000 miles ago the most. havent checked the o2 yet, how would i go about "testing" it anyway?
post Jun 4, 2010 - 4:26 PM
GriffGirl
Joined Feb 7, '07
http://www.ehow.com/how_5193043_test-sensor.html
post Jun 4, 2010 - 4:58 PM
6gc_ct
Joined Apr 5, '10
From conneticut
ok, so i just went and did that test. thank you griffgirl btw, with the car idleing at full temp the o2 stayed at 0.11 the whole time, even with the created vacuum leak, no change at all. so must be the sensor? might have done the test wrong? i dont think i did
also, would it still be possible its the o2 even though i dont and havent had a code for 02?
This post has been edited by 6gc_ct: Jun 4, 2010 - 5:13 PM
post Jun 4, 2010 - 7:12 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
If your car is 1996+ you can use an OBDII scanner with a live data function to watch the o2 sensor cycle realtime while the car is running. Also, you can check your Air/Fuel Ratio in realtime, it should be 14.7 ( stoichiometric ratio) or very close to that on an N/A car.
These scanners are cheap these days, can get a nice one that even does graphing for 119 bucks on amazon. Graphing Scanner
post Jun 4, 2010 - 8:01 PM
6gc_ct
Joined Apr 5, '10
From conneticut
94- OBDI here
post Jun 4, 2010 - 10:55 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
check and see if the egr is stuck open slightly. That can cause problems with running lean. Sometimes you can "knock" the valve loose and it'll close back up. Carbon could be building up in there causing the egr to stick open slightly and lean out the afr.
2nd Gen 3s-gte.... It lives!
97celiman
post Jun 5, 2010 - 8:50 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (6gc_ct @ Jun 4, 2010 - 4:58 PM) *
LEAN AFR - that is a code for the o2, it didn't fluctuate so the sensor is bad, its reading lean always... change the sensor
Breaking Axles...
post Jun 5, 2010 - 9:00 AM
QUOTE (pittfirefighter @ Jun 5, 2010 - 9:50 AM) *
X2.
thats why your lean, your O2 is bad.
Lo-Fi Version Time is now: December 2nd, 2024 - 3:06 AM
