> Idle Problem.
post Jun 12, 2010 - 2:06 AM
GilVilla
Joined Jun 17, '08
From Mexico
I have a celica 95 GT and the problem is that the engine's idle speed is 1,100 RPM and I can't adjusted to 750 RPM, I try to rotate the distributor, what else can I do?
post Jun 12, 2010 - 9:18 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Get a manual for our car. The kind you can buy at Pep Boys. Because it have one and it talks about a screw close to the throttle body that you can turn to adjust the idle speed to your preference. I'm not at home, otherwise I'd post what it says. Plus there's diagrams
June '12 COTM
'95 AT200
post Jun 15, 2010 - 1:46 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The distributor adjusts timing, not idle speed. Don't mess with the timing unless you know what you're doing.
Lo-Fi Version Time is now: November 25th, 2024 - 11:28 PM
