Enthusiast ![]() Joined Jun 23, '10 From Pawtucket, RI Currently Offline Reputation: 2 (100%) ![]() |
does any1 have a write up on how to install a indash dvd into a 6gc
-------------------- I only want to be faster than the guy next to me.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
It's really simple:
-twist off shift nob -carefully pull of the trim surrounding the shifter - pull off the trim around the radio. Its a little tricky but don't be scared to give it a good pull. next just remove the screws holding in stock radio. It should be two units, I believe its a cd player and then the radio. The two are held together by a a bracket. So unbolt the bracket and then you have to put the bracket on to your new screen (assuming its a double din screen not a flip.) Wire in the harness and your basically set to go. You can bolt the brackets into the car and then put all the trim pieces back in. I hope that makes at least a little bit of sense, If you need a hand let me know, I've had mine in and out numerous times. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Enthusiast ![]() Joined Jul 28, '09 From Christchurch, New Zealand Currently Offline Reputation: 1 (100%) ![]() |
if its a 7 inch dvd one like mine you may need to do some minor modifcation to the surround as the plastic hole may be slightly to small id recomend using a dremal tool but it can be done with a normal drill if you take your time although will not be as neat
Lo-Fi Version | Time is now: February 18th, 2025 - 6:51 PM |
