thump at idle CLOSED |
Jul 23, 2010 - 6:53 PM |
Enthusiast Joined Oct 14, '08 From Foxboro Currently Offline Reputation: 0 (0%) |
Recent change of plugs and wires and air intake..
Then reset fuel ecm. Now the engine bogs down and has no power, engine will rev then a clicking sound across all four points. Unless slowly letting out the clutch, but may loose drive changing to second gear. Also at idle a thump is felt thru the gas pedal near to every 45 seconds. This post has been edited by RESISTANT: Aug 1, 2010 - 10:00 AM |
Jul 24, 2010 - 12:25 AM |
plug wires on secure?
Jul 24, 2010 - 9:10 AM |
After market wires and they don't sit as tight to the top of the head as the original wires. I think it is secure.
There are hexagonal nuts i could remove for a tighter fit, but I thought they are for the plug tubes to stay tight. |
Jul 24, 2010 - 11:03 AM |
it sounds like a misfire, try to isolate which cylinder by lifting plug wires one at a time till you lift one and the idle does not change.
Aug 1, 2010 - 9:58 AM |
Thanks for the response
I went thru your system check and decided to replace the rest of the system and have gone with a new distributor cap and rotor. fuel filter and perhaps later some exhaust work. |
Lo-Fi Version | Time is now: November 30th, 2024 - 5:22 AM |
