> Engine Block?...
post Aug 5, 2010 - 1:12 AM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
I currently have my motor torn down, the number 2 cylinder looks pretty horrid.... Looking at the money aspect would it be cheaper to find a used block that just needs to be honed, or to have the one I have bored and get over sized pistons?... Not looking at the money aspect which would be the better option?
Scraps
post Aug 5, 2010 - 3:15 AM
Johnnyny
Joined Apr 28, '09
From York pa
if u got no money get a good used block i u do bore it !
post Aug 5, 2010 - 10:26 AM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
QUOTE (Johnnyny @ Aug 5, 2010 - 3:15 AM) *
Money isn't a problem.... I'm just trying to figure out which would be my better route....
Scraps
post Aug 5, 2010 - 11:24 AM
if money is not an issue, i highly suggest overboring .020. how bad is the cylinder? toyota does have oversized pistons, so if you want to repair the one cylinder you can. but for best results, do all 4.
post Aug 5, 2010 - 12:32 PM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
Do you know where I can find the oversized pistons for my 96 7a?
Scraps
post Aug 5, 2010 - 12:36 PM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
QUOTE (Smaay @ Aug 5, 2010 - 11:24 AM) *
I'm not sure how bad it is its just some scuffing.
Scraps
post Aug 5, 2010 - 3:39 PM
Sorry i dont know who makes 7A forged pistons. I have have some made from Diamond. i have a good relationship with them. i use them when i build high HP 2ZZ-GE engines.
if you just ahve some scuffing, then just get it re-honed. you should be just fine. then defiantly just get the oversized piston from toyota and ring set. not worth doing all 4
post Aug 5, 2010 - 8:50 PM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
QUOTE (Smaay @ Aug 5, 2010 - 4:39 PM) *
I tried honing it... Not so much luck... I'll post pics...
Scraps
post Aug 5, 2010 - 9:15 PM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
Do you think if I try to run the hone through some more it'll come out?
Scraps
post Aug 6, 2010 - 4:13 PM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
Bump...
Scraps
post Aug 6, 2010 - 11:57 PM
drag your fingernail along the scratches, it really doesnt look that bad. a good hone job might clean all that up. if your fingernail catches the scratch it might be too deep for a hone and you need to bore it.
post Aug 7, 2010 - 12:18 AM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
QUOTE (Smaay @ Aug 6, 2010 - 11:57 PM) *
Thanks for being so helpful dude!
Scraps
post Aug 10, 2010 - 2:06 PM
95celicastLSR
Joined Nov 16, '06
From Findlay,Oh
importperformanceparts.net can get u a set of pistons for the 7afe ... forged with any compression and size up to 82.5mm . stock is 81.0 mm. check them out on price as i dont know how much it would cost but i have the HP engine kit with forged pistons and all... which cost me just over 1000.00 .. on there website if u look they offer just a rod and piston combo, if u all ready have everything else to rebuild it may be a good choice if u want stronger internals ..
This post has been edited by 95celicastLSR: Aug 10, 2010 - 2:09 PM
post Aug 10, 2010 - 2:11 PM
1000 for forged pistons for a 7a.
Swap!
post Aug 10, 2010 - 7:50 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (njccmd2002 @ Aug 10, 2010 - 3:11 PM) *
Swap!
x2
post Aug 10, 2010 - 9:57 PM
95celicastLSR
Joined Nov 16, '06
From Findlay,Oh
QUOTE (Johnnyny @ Aug 11, 2010 - 12:50 AM) *
Swap!
x2
it cost me 1000 for the whole HP engine rebuild kit.... lol got to be nuts to pay 1000 for just pistons !!!
post Aug 10, 2010 - 11:04 PM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
I honed it some more and it finally smoothed out... I just have to finish my head now and I'm done.
Scraps
Lo-Fi Version Time is now: February 20th, 2025 - 2:57 PM
