more horse... less money |
Aug 8, 2010 - 4:50 PM |
Enthusiast Joined Jul 28, '10 From Wrentham, MA Currently Offline Reputation: 0 (0%) |
Hey guys I was wondering, what's the cheapest way to get some real extra horsepower, I plan on eventually doing a turbo and such but for now I'm sick of my dweeby friends blowing me away in there silly stock cobalt ss's and lancers
Aug 8, 2010 - 5:15 PM |
sad to say, but there really isn't anything that cheap that will give you a lot of extra horses. you could upgrade to an aftermarket intake (about 3 to 5 horses), do an a/c delete (a few extra horses), and use higher octane fuel. I believe those are the cheapest routes to go. anything else will cost you a pretty penny.
Aug 8, 2010 - 5:17 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
first- search.
second, there is no cheap way your going to beat out a lancer or a cobalt SS, they are just factory faster, and not to mention more than likely newer. You can get an intake and exhaust, but it doesnt give you as much as you may think. Save and swap, or turbo. Either one...will Not be done cheaply -------------------- |
Aug 8, 2010 - 5:31 PM |
Enthusiast Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
Boost.
Aug 8, 2010 - 5:39 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
sad to say, but there really isn't anything that cheap that will give you a lot of extra horses. you could upgrade to an aftermarket intake (about 3 to 5 horses), do an a/c delete (a few extra horses), and use higher octane fuel. I believe those are the cheapest routes to go. anything else will cost you a pretty penny. Unless he puts in 108 octane or race fuel, that doesn't matter. When you're using pump gas, the octane ratings are so close together, it really doesn't matter what you use. Unless of course you have a Lexus or a Mercedes that the factory says you must you premium. Then if you use regular, you'll be hurting your engine. But contrary to common belief, higher octane pump gas doesn't make you go faster. -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Aug 8, 2010 - 5:43 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
You said dweeb? For realski? Niiiice
Aug 8, 2010 - 7:05 PM |
Unless he puts in 108 octane or race fuel, that doesn't matter. When you're using pump gas, the octane ratings are so close together, it really doesn't matter what you use. Unless of course you have a Lexus or a Mercedes that the factory says you must you premium. Then if you use regular, you'll be hurting your engine. But contrary to common belief, higher octane pump gas doesn't make you go faster. Exactly. You can pump 87 or 93 but it's not going to make a difference in your low compression NA setup. Boost your car or have a high compression engine and then it matters. Otherwise you're wasting money. OP- There's no cheap way to get extra power. Just congratulate your friends got having quick, fun cars and don't drive yours like a tool. You don't have to go fast to look good. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 8, 2010 - 7:16 PM |
Exactly. You can pump 87 or 93 but it's not going to make a difference in your low compression NA setup. Boost your car or have a high compression engine and then it matters. Otherwise you're wasting money. I know this. But back to the OP, he wanted a quick, easy, and cheap way to go fast. Boosting a car is by no means a quick, easy, and cheap process. So like I said, it doesn't matter the octane he uses. -------------------- taking too long to mod since '09
Aug 8, 2010 - 7:33 PM |
I did hear that if you run your car on higher octane (or toss it in every once in a while), that it is better for the engine in some ways (not to get off topic). But thanks for letting me know it doesn't do anything unless you have a turbo
Aug 8, 2010 - 9:30 PM |
Enthusiast Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) |
Higher octane gas is less prone to pre-detonation aka knock. There really is no way to get huge power gains. I think what you could do though is advance your timing and you might net a few ponies doing that. Also a well set-up CAI with a full exhaust job would net you a bit of power. Then you can tune a bit using an safc if you have a logger and wideband. You couple all that with a bit of weight reduction mods and you'll be a bit quicker. When all is said and done you might gain like 15-20whp spending around $200-$400 on a good day I'm assuming. So its really up to you.
This post has been edited by Nartanian: Aug 8, 2010 - 9:33 PM -------------------- "God created turbo lag to give V8's a chance"
Aug 8, 2010 - 10:44 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
please use the search feature and read and read and read what everyone else has already covered. It's simple, you won't beat them without cheap mods. just be happy you have a nice car to drive.
I got friends with 300+ HP RSX-S turbo and they respect me for having one of the cleanest looking cars around. -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Aug 8, 2010 - 10:47 PM |
Just for future reference w/ a full swap or partial w/ turbo and exhaust and intake.. uk th works... how much can I really be pushin horse?
Aug 9, 2010 - 10:47 AM |
Enthusiast Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) |
200+hp with turbo
more with swap it all depends on your set up but seriously search around the forum -------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
Aug 9, 2010 - 10:59 AM |
What he said, You boost the 5s prob like 230-300ish. You swap: 250 just by swapping, then some basic bolt ons and boost controller your looking at 300+.
Aug 9, 2010 - 11:00 PM |
thanks a ton for all the input ive been pretty much reading at least one whole section of the forums a night now a day so im trying to be less noob, i hope someday i can be as knowledgable and have a nice ride like you guys haha thanks again
Aug 9, 2010 - 11:16 PM |
don't worry about it. we were all noobs once. I myslef spent weeks and weeks reading and stalking on here before i even knew what to do with my car. good to see ur reading up. especially if ur thinking about turboing. It'll be a big long read. good luck with whatever you do.
Aug 9, 2010 - 11:26 PM |
thanks bud, ya, after all the info ive read i think i wanna do a full swap and turbo, i want power, problem is i dont have a whole lot of mechanical know how and i want to do as much as i can myself, looks like ima need to make more friends who know what theyre doing lol
Aug 12, 2010 - 1:39 AM |
Enthusiast Joined May 28, '10 From Oakley, Ca Currently Offline Reputation: 1 (100%) |
thanks bud, ya, after all the info ive read i think i wanna do a full swap and turbo, i want power, problem is i dont have a whole lot of mechanical know how and i want to do as much as i can myself, looks like ima need to make more friends who know what theyre doing lol same here buddy! we know what we want and have no idea how to do it!!! |
Aug 12, 2010 - 6:15 PM |
hahaha yep time to start learning!
Aug 12, 2010 - 7:56 PM |
Enthusiast Joined Aug 11, '10 From Alberta Currently Offline Reputation: 0 (0%) |
Hey guys I was wondering, what's the cheapest way to get some real extra horsepower, I plan on eventually doing a turbo and such but for now I'm sick of my dweeby friends blowing me away in there silly stock cobalt ss's and lancers If they have Turbo Cobalt SS's and Evo Lancers you will NEVER be able to keep up without a turbo, I had a 2009 Cobalt SS Turbo and it was an STI/EVO eater. BEST option lol get a GT-4 This post has been edited by RockyMountainCelica: Aug 12, 2010 - 7:57 PM -------------------- 2009 Chevy Cobalt SS Turbo "Torque Monkey" SOLD
1993 Honda Civic Si "Mean Green Cornering Machine" Track Whore 1995 Toyota Celica GT "Baby Supra" Daily Driver |
Lo-Fi Version | Time is now: January 10th, 2025 - 4:21 AM |
