> Projek_01's build/restoration tread =D
post Aug 11, 2010 - 1:24 AM
Projek_01
Joined Feb 18, '07
From Calgary, Alberta
I never thought I would have one of these threads!
This starts off with a good-ol 7th Gen Celica wheel. Looks like we have a problem with the cruise control wiring and controls. Each toggle on the cruise control has it's own resistance value. The 6th Gen Celica and the NewCelica use different resistance values so this means open heart surgery. I havent seen a how-to before so if there is demand, ill make one.
The 6th gen stalk PCB with larger resistors with lower resistance
The 7th gen stalk PCB with smaller resistors.
THe 6th Gen resistors were transfered over to the new stalk. The plastic around the resistors had to be cut away to make room for the larger components. Careful soldering is required.
The harness is spliced on to plug into the 6th Gen clock spring.
This post has been edited by Projek_01: Aug 11, 2010 - 1:25 AM
post Aug 11, 2010 - 1:33 AM
Projek_01
Joined Feb 18, '07
The parts are rolling in and filling up my dad's precious shed.
Here is a teaser!
post Aug 11, 2010 - 2:03 AM
chacha
Joined Dec 29, '05
From So-Cal
new weather stripping?
post Oct 21, 2010 - 11:07 PM
Projek_01
Joined Feb 18, '07
yes sir! I haven't updated this thread for awhile. Trying to balance school and working on the car!
post Apr 3, 2011 - 10:41 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (Projek_01 @ Aug 11, 2010 - 12:33 AM) *
Here is a teaser!
post Apr 7, 2011 - 12:42 AM
i did the cruise a while back...
http://www.6gc.net/forums/index.php?showto...ccmd2002+cruise
post May 19, 2011 - 1:15 AM
KAOS
Joined Apr 18, '06
QUOTE (Projek_01 @ Aug 11, 2010 - 12:24 AM) *
The 6th Gen resistors were transfered over to the new stalk. The plastic around the resistors had to be cut away to make room for the larger components. Careful soldering is required.
So; I've just started this project as well... what you're saying here is all that needs to be done is all three 6th gen stalk resistors need to be swapped to the 7th gen stalk? and then I can use the 7th gen stalk like normal?
This post has been edited by KAOS: May 19, 2011 - 1:18 AM
post May 19, 2011 - 11:08 PM
Projek_01
Joined Feb 18, '07
New Update!
Eastwood Fender roller so I dont have to worry about cracking any paint later on.
Single stage BASF finish in door jams and hatch.
Looking forward to the 040 color change! About another week till the whole car will be towed to the shop and sprayed with DuPont ChromaBase and ChromaClear 040.
This post has been edited by Projek_01: May 19, 2011 - 11:09 PM
post May 19, 2011 - 11:11 PM
KAOS
Joined Apr 18, '06
QUOTE (Projek_01 @ May 19, 2011 - 10:08 PM) *
New Update!
Soooo... you should leave that little paint booth set up and we can paint mine too while you're at it. wink.gif
I might need your fiberglassing help with my new C-One bumper anyways, if you're willing. tongue.gif
post May 19, 2011 - 11:29 PM
Projek_01
Joined Feb 18, '07
btw, can a mod move this thread? you guys didnt have the new topic yet when i made this.
post May 24, 2011 - 12:29 AM
Projek_01
Joined Feb 18, '07
off to the body shop tomorrow!
its rainy outside so i decided to work on something inside
going for the supra blacked out badge look without spending the big bucks.
This post has been edited by Projek_01: May 24, 2011 - 12:30 AM
post Mar 10, 2012 - 8:33 PM
Projek_01
Joined Feb 18, '07
Didnt really update my thread after my car came out of the booth. I was a little depressed because the paint was quite oranged peeled and had poor coverage. A quick wetsand/pp helped a fair amount.
Wanted a second attempt at painting a 6GC..
I would say that my Celica is basically done. I am leaning towards saving money for something with more power and reliability and just using the 6gc with the blizzaks for winter.
This post has been edited by Projek_01: Mar 10, 2012 - 8:42 PM
post Mar 19, 2012 - 11:20 AM
KAOS
Joined Apr 18, '06
post Mar 19, 2012 - 11:35 AM
rave2n
Joined May 29, '09
From Gainesville, FL
Lo-Fi Version Time is now: November 27th, 2024 - 6:46 PM
