Huge misfire, Help please. Misfire issues |
Aug 19, 2010 - 8:53 AM |
Enthusiast Joined Aug 19, '10 From orlando Currently Offline Reputation: 0 (0%) |
ive got a 94 gt
I got a misfire when I idle at 2k to 3k rpms. Ive changed spark plugs, wires, cap and rotor and distributer coil. Im stuck on this. Im wasting so much gas.. getting like 20mpg. any ideas? thanks in advance |
Aug 19, 2010 - 1:21 PM |
Enthusiast Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) |
What cylinders misfire? I say do a compression test. You might be misfiring due to low compression.
-------------------- "God created turbo lag to give V8's a chance"
Aug 19, 2010 - 2:07 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
are you burning up any oil (i assume coolant could do it as well) When I had my old 7a I replaced all this stuff, but i did a test (cylinder leakage test? idr now) and found that the piston ring in cylinder one was bad, and so much oil (i burned a quart a day minimum) was getting in the combustion that it wasnt actually firing, and causing it to misfire. Just an idea to rule out
Aug 19, 2010 - 10:43 PM |
Enthusiast Joined Apr 7, '09 From cali Currently Offline Reputation: 0 (0%) |
need more info ...first off Idle at 2k to 3k .....techinically thats not idling ...unless its at 2-3k without you touching the pedal
most people interpret a missfire as many different things can you explain more in depth how you can recreate this missfire ? your speed mph ? are you on the throttle 100% ? has the car have recent work ? when did this start happening ? during this missfire what kinda noise do you hear ?does the rpm stumble? was this car non operative for a long time? any smoke during missfire? any smoke at start? strange smells ? does it happen as your moving the throttle ? is your engine covered in oil dirt or grime heavily anwhere? |
Lo-Fi Version | Time is now: December 2nd, 2024 - 9:24 AM |
