> Blown midpipe gasket, can i use high temp silicone?
post Sep 14, 2010 - 1:58 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
So the other day my car starts to sound like there is a slight vibration in the midpipe, that slight vibration turns out to be a blown out exhaust gasket between the midpipe and the header, did i mention no stores around here carry gaskets for the aftermarket header? so my question is, can i use high temp silicone to fix this? says its good to 650 degrees so can i use this to replace the blown out one?
2001 Solar yellow Lexus IS300
post Sep 14, 2010 - 3:23 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
QUOTE (96stgreendemon @ Sep 14, 2010 - 2:58 PM) *
You can use that for a temp fix but if you can't find a gasket i would suggest using Permatex muffler and tailpipe sealer. You should be able to find it at any local auto store. I use without a gasket and i haven't had a leak yet. Although it is a little messy, and sometimes difficult to clean. It gets the job done and is supposed to be resistant up to 2000 deg. Good luck!
post Sep 17, 2010 - 9:09 AM
96stgreendemon
Joined Oct 7, '09
Wow this worked for about a day....
post Sep 17, 2010 - 11:14 AM
those gaskets should be available in you local stores by mail order...
post Sep 17, 2010 - 4:19 PM
96stgreendemon
Joined Oct 7, '09
Finally found the gasket today, well similar had to modify it a little but it works now, found it at an exhaust shop
Lo-Fi Version Time is now: December 11th, 2024 - 6:05 PM
