> Help!!! Front end issues
post Sep 15, 2010 - 9:18 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Ive had my coilovers on for about a month now, no issues, its been aligned and all that, last night while driving home i hit a small pothole that couldnt be avoided, a few minutes later i noticed that my steering wheel is to the left and im going straight, still confused, get off the exit and now every time i turn somewhat hard the tires sequel, someone help?
2001 Solar yellow Lexus IS300
post Sep 15, 2010 - 10:12 AM
Culpable04
Joined Apr 17, '06
From New Jersey
do a visual inspection and look for bent / broken suspension parts. sometimes it can'e be spotted as easy, but ytour car will definately need to be re alighned at the very least, that's if you are lucky, if you are like me, you'll need a new control arm ( been there already )
post Sep 15, 2010 - 12:09 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Suuuucks kindasad.gif When I was in my accident, My alignment got SCREWED due to obviously, taking the blunt hit in the LH wheel area, and a bent strut kindasad.gif That was an 18 wheeler wheel, you hit a pothole. I don't think it'll be that bad, but good luck smile.gif
June '12 COTM
'95 AT200
post Sep 15, 2010 - 12:16 PM
whatthe
Joined Aug 13, '08
From Australia
Jack up the car take off the wheel. Check if everything is tightand secure. If any arms are bent. Check if the wheel itself is cracked or bent. Get an alignment too. But if theres noise somethings ****ed.
This post has been edited by whatthe: Sep 15, 2010 - 12:17 PM
post Sep 15, 2010 - 12:32 PM
96stgreendemon
Joined Oct 7, '09
Finally got home from school today, the alignment is not too far off its just the steering wheel thats bugging the crap out of me, popped the hood when i got home and looked at the wheel, no cracks or anything like that, but my camber is WAY negative, so im gonna fix that and hopefully get a friend to do the alignment tomorrow
post Sep 15, 2010 - 12:36 PM
whatthe
Joined Aug 13, '08
From Australia
You need to pop the hood to inspect your rim o.O What kind of celica do you have ?!?
post Sep 15, 2010 - 3:04 PM
96stgreendemon
Joined Oct 7, '09
no popped the hood to check out the camber plate lol
post Sep 15, 2010 - 3:06 PM
HectortheRican
Joined Dec 26, '09
QUOTE (whatthe @ Sep 15, 2010 - 11:36 AM) *
LOL!
June '12 COTM
'95 AT200
post Sep 16, 2010 - 7:17 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Only way to tell is when its on the alignment machine, they will tell you if it doesn't line up straight and IF it doesn't its most likely a control arm or strut, Mine were bent after someone drove into me and you couldn't tell just by looking.
post Sep 16, 2010 - 8:37 AM
96stgreendemon
Joined Oct 7, '09
fixed the problem with the alignment, when i hit the pothole it MOVED my camber plate all the way to negative, fixed that and all is now well
post Sep 16, 2010 - 10:02 AM
HectortheRican
Joined Dec 26, '09
QUOTE (96stgreendemon @ Sep 16, 2010 - 7:37 AM) *
Damn! I must have completely over-powered those teeny bolts holding it in place, huh? Glad it's fixed smile.gif
June '12 COTM
'95 AT200
post Sep 17, 2010 - 9:09 AM
96stgreendemon
Joined Oct 7, '09
i smacked the hell out of that pothole
Lo-Fi Version Time is now: January 11th, 2025 - 6:39 PM
