> 7AFE Fluid Data Specs., Based on a 1995 but should apply to other years
post Sep 18, 2010 - 6:44 PM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
Hey Guys! Here is the promised 7AFE chart. Thanks!
Application - Fluid Type : Capacity = Litres (U.S. quart , imperial quart)
A/C Refrigerant. - R134a : 650 +/- 50g (22.93 +/- 1.74oz)
Air Condition Oil - ND-Oil 8 or equivalent
Brakes - SAE J1703 DOT 3
Clutch. - SAE J1703 DOT 3
Differential Oil (manual Transmission)
- ATF Dexron II or III : 1.6L (1.7, 1.4)
Engine Oil (Dry Fill)........................................ - SH "E-C II" : 4.3L (4.5, 3.8)
Engine Oil w/filter change (Drain & Refill) .. - SH "E-C II" : 3.7L (3.9, 3.3)
Engine Oil w/o filter change (Drain & Refill) - SH "E-C II" : 3.5L (3.7, 3.1)
Engine Cooling System (Manual).... - Ethylene glycol base (no alcohol) : 6.1L (6.4, 5.4)
Engine Cooling System (automatic) - Ethylene glycol base (no alcohol) : 6.6L (7.0, 5.8)
Fuel Tank - Unleaded OR87 (RON91) or Higher : 60L (15.9 gallons, 13.2 imperial gallons)
Power Steering
- ATF Dextron II or III : 0.8L (0.85, 0.70)
Automatic Transmission A246E
Dry................ - ATF Dextron II or III : 7.6L (8.0, 6.7)
Drain & Refill - ATF Dextron II or III : 3.1L (3.3, 2.7)
Manual Transmission S54 - API GL-3, GL-4 or GL-5 SAE 75W-90 : 2.6L (2.7, 2.3)
post Sep 19, 2010 - 8:46 PM
kormysh8
Joined Nov 14, '09
From Saskatoon
Niiiceee man, thanks a lot! thumbsup.gif x10
post Sep 19, 2010 - 8:48 PM
Wow that's great. Awesome! Thanks.
post Sep 22, 2010 - 6:11 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
*like*
Lo-Fi Version Time is now: January 10th, 2025 - 12:33 AM
