> Brakes "creek" when pushed down (slow or stopped), read, wondering if anyone knows, little hard to explain
post Sep 24, 2010 - 12:54 AM
mgnt232
Joined Mar 16, '09
So i recently noticed this odd noise my "brakes" make (imagine it is the brake since it only happens when they are depressed tongue.gif)
It is only when I am parked (starting my car I press it in to take off the ebrake and can hear it) or like rolling to a stop sign at 5mph (or at least this is when i can hear it).
When the pedal is depressed, it goes down a slight bit, and then starts to feel harder as i push further. After the initial push when it gets hard, if i push slightly past that (only when im coming to a complete stop, or taking the ebrake off. I never push the brake further any other time) The front brakes kind of creek (sounds like it comes from the front).
I can only explain it as like an eerie sound of a creeky door
Braking is not any different since it started (at least nothing major)
I was wondering if this is a sign of the caliper going? I replaced the pads and rotors when i got the car, but not the calipers, and I imagine the condition everything else on my car was, that they are pretty old.
Its an odd sound, hard to explain, maybe ill get a video
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Sep 24, 2010 - 12:59 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
I got my brakes all around replaced (front rotors/pads, rear drums/shoes) not even 150 mi ago and they still do it sometimes. I don't think it's anything. I mean, new brakes, c'mon. Haha
June '12 COTM
'95 AT200
post Sep 24, 2010 - 11:14 AM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
it is the little shims that hold your pads in place, they are usually rusted a bit and naturally rubb up against the caliper making that noise, if u have a brake job done they should use a bit of siliglide so that the shims can slide with out creekin like they do. i did mine yesterday and all that noise went away. or it couls be a frozen slider pin in the caliper, i had one on mine, so i took a acetylene torch to it and wiggled it out and lubed it up, this prevents your brakes from possibly dragin and making that noise.
This post has been edited by 4-eyed-freek: Sep 24, 2010 - 11:17 AM
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
Lo-Fi Version Time is now: January 11th, 2025 - 2:05 AM
