> Swap Prep, MOAR PIX!
post Oct 10, 2010 - 10:08 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
whats up guys, jeez im tired after that fiasco today! had to find a better place to start preppin the 3s (puttin on h2o pump,cam seals etc) and realized how truly heavy that motor is with the AWD on it...
But anywho i had some quick questions before me and my buddy lay hands on it.
as far as taking the tranny off (caldina AWD) is there anything i should be particularly mindful of? or any tricks you all know of? please share!
when i replaced my harmonic balancer before, the motor was IN the car, and loosening it wasnt TOO bad because we used some suggested tricks (like using prybar against the ground while starting car to loosen bolt) But now since the motor is out, will i have any trouble getting the bolt off? we should have some power tools, but i remember it beign a PITA without it.
also does anybody know the torque specs for the harmonic balancer? i couldnt find it after a long search.
i'll try to take some pics while we're pokin about with it.
This post has been edited by easternpiro1: Feb 21, 2011 - 3:29 PM
post Oct 11, 2010 - 9:16 AM
I think its around 80ftlb.
Oh, replace your oil pump seal and o-ring.
post Oct 11, 2010 - 10:04 AM
if you've already taken the bolt out once, it shouldnt be to bad this time with an impact wrench.
do whatever maintinence the timing belt side needs while the motor is out, and the rear main seal as well.
i always try and think about how much harder certain things are to do (like the timing belt/water pump stuff) with the motor in the car, and make sure those are all taken care of while the motor is out.
if your not 100% sure about taking things off, just be sure to bag and label anything you remove, and taking pics sometimes helps to refresh your memory when you go to reinstall things.
just take your time, dont rush things.
as a side bonus, anything you clean up, paint, coat or whatever now, will make you 10X happier once its in the car.
post Oct 11, 2010 - 12:49 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (lagos @ Oct 11, 2010 - 9:16 AM) *
damn i think i forgot to order that part!
QUOTE (presure2 @ Oct 11, 2010 - 10:04 AM) *
thanks guys! as far as the harmonic balancer bolt is concerned, its a different motor, im taking the harmonic balancer from my blown 3s because that one is brand new (i got it from that guy in florida that scammed everyone) and putting it on this one.
i've bought all the goodies from lagos to put on there because i remember how much of a royal presidenital PAIN it is to get that stuff in once motor is in tongue.gif
i do plan to paint my valve cover gasket since im takin that off as well to replace cam seals, just waiting for the gaskets to come in (thanx doc!)
What else should i paint manny? i was thinking about the timing belt cover (since i have an extra one) but that may not come out too well.
will keep ya'll updated!
post Oct 11, 2010 - 2:27 PM
mak5603
Joined Oct 20, '08
QUOTE (easternpiro1 @ Oct 11, 2010 - 1:49 PM) *
Painted gasket FTW, lol.
For reals though, I will be doing pretty much everything mentioned in this thread myself as my fresh motor is coming in soon. Thanks in advanced eastern and everyone else for the info.
2014 Toyota Rav4 XLE
post Oct 11, 2010 - 6:37 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
lol! painting valve cover gasket FTL
youre welcome man, but what'd i do? lol
post Oct 11, 2010 - 7:19 PM
mak5603
Joined Oct 20, '08
Start a thread about stuff to remember for swap prep. And I am currently in the swap prep process. smile.gif
post Oct 11, 2010 - 7:30 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (easternpiro1 @ Oct 10, 2010 - 11:08 PM) *
dont do what i did and crack the upper oil pan near the clutch dust cover!!!!!! lol i was using a big a$$ screw driver and driving it around the tranny with a hammer and i started wackin the screw driver deeper and deeper around the tranny in one spot and POP! i cracked it. it was an easy fix tho. pics of the crack r in my thread. havent posted repaired pics yet
st205 powered ss3 coupe
post Oct 12, 2010 - 10:56 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (mak5603 @ Oct 11, 2010 - 7:19 PM) *
im sure there are like 188383739 threads on this dont want to repeat a thread HOWEVER i did mention alot of the necessary things in this thread:
http://www.6gc.net/forums/index.php?showtopic=75910
I didnt get idler pulleys b/c i already have some from the blown motor in the trunk somewhere.
QUOTE (Ted95 @ Oct 11, 2010 - 7:30 PM) *
I will be sure to keep that in mind!
oh man, u know what just occured to me.... we took the motor out from the bottom!!!
DAMNIT! me and tweak gonna have a headache puttin it back in... frown.gif i fail.
post Oct 12, 2010 - 11:09 AM
DEATH
Joined Dec 19, '07
From tx
Piro - Plz do me a favor and take lots of pics of the valve cover gasket/Toyota FIPG install. I'm leaking like mad from there and am about ready to instal a new gasket and that custom powdercoated VC I bought two years ago LOL.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Oct 12, 2010 - 12:03 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (DEATH @ Oct 12, 2010 - 12:09 PM) *
gotcha! but the 4th gen valve cover gasket is 2 part from what doc Tweak told me. i dont remember it being two parts when i took it off before, but then again i have bad memory and it was back in december or jan. when i did it
mak5603
Joined Oct 20, '08
QUOTE (easternpiro1 @ Oct 12, 2010 - 10:56 AM) *
There are, and I have read most of them, but this thread had smaller less obvious swap prep things mentioned.
post Oct 12, 2010 - 12:16 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (mak5603 @ Oct 12, 2010 - 1:03 PM) *
ah gotcha!
i can mention them right here, i have the list right here
cam seals (not expensive FTW)
FRONT AND REAR main seals
thermostat
waterpump (dont forget gaskets that go on it)
idler pulleys (i didnt b/c i got some extras that i KNOW work)
some people say belt tensioners
of course a good ol OEM timing belt (nothin fancy schmancy like HKS unless youre gonna do some serioius tuning)
V-belts (which i recently learned are also called accessory belts (alternator pow. steering etc)
oil pump gaskets
for NORMAL folk all of this stuff would cost OVER 200 bucks
but for the KINGS of the earth that drive 6gc's total was like 170 From good ol lagos and his buddys at the illadelphia toyota ya cant beat toyota quality for that price!
This post has been edited by easternpiro1: Oct 12, 2010 - 12:16 PM
post Oct 12, 2010 - 1:13 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (easternpiro1 @ Oct 12, 2010 - 12:03 PM) *
It IS technically two peices if you count the one peice that goes around the #2 and #3 sparkplug tubes and the center hold down bolt. All of the gens have that setup IIRC. But then again my memory can be pretty bad too and it's been 5 years since I tore down my Caldina clip.
Perhaps the main gasket is two parts on the Caldina? IDK. Let's research this and include it.
Can anybody provide pics of all 4 generations of the 3S-GTE?
EXT: WRC/TRD/404
post Oct 12, 2010 - 2:49 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
i got my other 4th gen head (WHICH IS FOR SALE if anyone wants it tongue.gif ) I'll take pics when i get off work, unless somebody beats me 2 it.
This post has been edited by easternpiro1: Oct 12, 2010 - 2:49 PM
post Oct 19, 2010 - 2:32 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
AWD tranny OFF whew what a PAIN!
Motor on the way to pals house to tear down
gotta pressure wash this mess! (that damn thing i bought thats supposed to be a screw on hose pressure washer is a SCAM!
engine bling!
This post has been edited by easternpiro1: Oct 19, 2010 - 2:34 PM
post Oct 21, 2010 - 3:46 AM
go to lowes sears or home depot when it gets a little colder i got a good deal for 125 bucks...
post Oct 21, 2010 - 7:33 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
Now that you removed the tranny, you can place a pry bar between one tooth of the flywheel (driveplate) and a engine-bloc-to-tranny bolt. Then, you can loosen your crank pulley bolt because the crankshaft wont move with the pry bar blocking the flywheel from turning. This is what I did and it worked nicely.
Good luck with the swap!
Sam
post Oct 22, 2010 - 5:55 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (njccmd2002 @ Oct 21, 2010 - 3:46 AM) *
ah but im taking it to S.C. for some tweakin next week! need to get hold of one soon! if not just rent! iirc lowes rents them?
QUOTE (pitcelica @ Oct 21, 2010 - 7:33 PM) *
Sam
thanks sam! glad you mentioned that! that crank pulley bolt wouldnt come off last night! thought it was because the airgun was too small... so just wedge a prybar in there eh? thanks! was wondering how to get it off!!
post Oct 22, 2010 - 8:23 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
damn. the water pumps are different! well it seems the housings are. will post pics lata. on cellie now.
Lo-Fi Version Time is now: November 30th, 2024 - 2:27 AM
