Enthusiast ![]() Joined Aug 15, '10 From UK Currently Offline Reputation: 0 (0%) ![]() |
Hiya folks...having seen this question asked a few times. I have been busy customising/restoring my Celica so put together a DIY with pictures to help.
1. Remove door weatherstrip. ![]() 2. Weatherstrip end clips to be removed...a sealant glue may also be used on the ends but easily removed. ![]() 3. Using clip tool to pop off clips...screwdriver works as well. ![]() 4. Weatherstrip removal exposes screws to be removed next. ![]() ![]() ![]() 5. Door edge trim removed. ![]() 6. Top window edge removed. ![]() 7. Removing seat belt top...flip up cover to expose bolt to be removed. ![]() ![]() 8. Removing coat hanger...pop off cover to expose a screw to be removed. ![]() ![]() 9. Remove speaker grill to expose screw to be removed. ![]() ![]() 10. Remove door lip trim and push interior trim off door edge. ![]() ![]() 11. Pull interior trim out a little to expose a philips headed plastic clip to be removed. ![]() 12. In boot area behind seat there is another philips headed clip to be removed. ![]() 13. Now you pull off the interior window trim off...held in by several clips...take your time. ![]() ![]() 14. Continue to pull trim off completely...place out of way for window removal. ![]() ![]() 15. Tape up the outside of window to avoid breaking it. ![]() 16. Using an extendable knife of good quality. ![]() ![]() 17. Cut into window sealant...go around the whole window. This will take a while...you will feel the blade hit metal once you are through all the way. ![]() ![]() 18. Quarter window and trim removed. ![]() ![]() 19. It is quite surprising how much sealant is used on these windows... ![]() Grab yourself a cold drink...job done! This post has been edited by CelicaHD2: Oct 12, 2010 - 3:51 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) ![]() |
Nice write up - vote for sticky
-------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) ![]() |
![]() Enthusiast ![]() Joined Jun 9, '07 From Miami, FL Currently Offline Reputation: 9 (100%) ![]() |
Good stuff, should be stickied for sure.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) ![]() |
awesome!! i bet lots of people will find this handy!
sticky! -------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
![]() Enthusiast ![]() Joined Jan 11, '07 From Fort Lauderdale, FL Currently Offline Reputation: 0 (0%) ![]() |
finally someone has pics on this. you are the quarter window god.
question. what will be needed to remove all the left over sealant, elbow grease? some kind of goo-gone? This post has been edited by gabyz: Oct 17, 2010 - 10:21 PM -------------------- |
I used the same knife I used for cutting out the window and cut off most of the sealant...then used a razor blade to trim to further down.
You can buy "sealant removing" chemicals or a rubber "decal removing" wheel but is not necessary. As long as you have no more than 3mm of sealant left...that is perfect for re-fitting of the glass. This post has been edited by CelicaHD2: Oct 18, 2010 - 1:52 PM |
Enthusiast Joined Jan 2, '13 From timothy0 Currently Offline Reputation: 0 (0%) ![]() |
Last step is hard. Take your time and use an extended knife of good quality.
This post has been edited by Timothy: May 19, 2015 - 5:33 PM |
Lo-Fi Version | Time is now: February 17th, 2025 - 5:05 AM |
