Enthusiast Joined Sep 3, '10 From CA Currently Offline Reputation: 0 (0%) ![]() |
so the other day i pulled the plugs out of my 1997 celica's 5s-fe and looked at them and found some oil on the one in cylinder 2
![]() ![]() im wondering what possible causes there are for oil to be in only cylinder 2 and 4 .. -------------------- |
![]() Enthusiast ![]() ![]() Joined Feb 24, '09 From Scranton, PA Currently Offline Reputation: 13 (100%) ![]() |
deffinitly not in the correct place to be posting this question...but idk one of my plugs was oily when i took it out one time..car still runs though
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) ![]() |
Was the oil in the cylinders, or in the spark plug tubes? If it's in the spark plug tubes then you just need to replace your valve cover gasket. If you're accumulating oil inside the cylinders in heavy amounts, well you have bigger issues.
-------------------- 1999 Celica GT
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
spark plug tubes (as previously stated) valve cover gasket is likely
inside the cylinders, sitting on top of the piston, valve seals/guides or piston rings |
ya the car still runs fine for the most part.. it just has a puff of blue smoke on start up then clears right up..
thanks for the tips.. ill double check on if it was just from in the tubes tomorrow, i just remember when i pulled plug 4 it was actually DRIPPING oil ![]() im hoping that its just a valve cover gasket.. not a head gasket or the valves or rings ![]() -------------------- |
replaced the valve cover gasket today and the tube gaskets.. those were pretty old and crusty looking.. so im hoping that that fixes the oil prob!! ill keep updated and tell ya if its all cleared up!
![]() Enthusiast ![]() ![]() ![]() Joined Nov 24, '07 From Tucson, Az Currently Offline Reputation: 2 (100%) ![]() |
my father (eventually passed it down to me) ran our car (also a 97 but an ST) for several years with a similar problem... it eventually started billowing out smoke... eventually this happened: http://www.youtube.com/watch?v=FTWFLFDgtow
so if you are having oil in your cylinders I'd suggest looking into at least getting a head gasket kit... it'll be a good amount of work, but it should help a bit. this will also give you a chance to look at the condition of the cylinders and pistons... good luck, Kevin |
just did a compression test.. the shop manual says its suppose to be 178.. but mine came out to be 180-190-190-190
so im guessing no blown head gasket or rings ![]() any ideas? thanks -------------------- |
oh and here is some pics
![]() with the valve cover off.. ![]() and i decided to paint the valve cover ![]() ![]() -------------------- |
Enthusiast Joined Nov 15, '10 From MA Currently Offline Reputation: 0 (0%) ![]() |
Most likely valve seals. Not too bad to do yourself if you have the book, the right tools, and some mechanical inclination.
![]() Enthusiast ![]() ![]() ![]() Joined Nov 25, '08 From dillsburg pennsylvania united states Currently Offline Reputation: 12 (100%) ![]() |
pos head gasket if it smokes when u start it thats the oil burning up and blowing out.
-------------------- ![]() those with golf balls golf those with real balls race |
Lo-Fi Version | Time is now: February 18th, 2025 - 3:11 AM |
