Enthusiast ![]() Joined Feb 23, '05 From New York Currently Offline Reputation: 0 (0%) ![]() |
Ok,
I decided to make 6G Celicas Forum my home. So far the only thing I don’t like is that I cant attach pictured, not sure if I need to be a gold member or not but I’m sue we will get past that. A little background, I was one of the first people to successfully put a 3S head on a 5S block way back when and have had a few versions of what’s now called the 5S-GE/GTE. I have built a 86 Celica GT NA that was really fast and only saw street racing and was never really tuned with a EMS. I have built a 91 MR2 that made 180whp on EMS NA with a 2.2 5SGE engine with a Gen 3 3S-GE head, I am in the process of getting a lot of bugs sorted out and should be putting down aprox 220-260whp soon. Now I’m in the process of building my 94 Celica GT Hatch. Info / thought process on my build: I’m looking to go after the world fastest FWD Celica and and make close to or more than 800whp and it be rev-happy. I have a custom build 2.1L stroker engine that has a JDM Celica ST205 3S-GTE Group Spec A head, a 2.2 5S-FE Camry US bottom end, a Second Gen 3S-GTE 2.0 Mr2 turbo crank, with pauter rods and custom 8.5:1 CP Pistons. The head was build by mr2power.net and it has custom cut blank 1mm OS ferrea valves, radius angle valve job, port and polish, ceramic coating on the combustion chamber, dual valve springs from the super 2JZ and shimless buckets under my HKS 272 cams, I have the Turbonetics T72 dual BB turbo with the water-cooled option. I have a custom dual stage injection manifold with an extra set of injectors on each runner which totals out to 8 injectors on the engine. I plan on tuning the system with E85 and or meth (this may change later on). I have a custom one off Full race exhaust manifold build by them locally. I actually got them to come out to NJ and I had my car towed from NY to their local shop to build it for me. I also had them build me a 3-4 inch down pipe to hang off the turbo. Once I have the transmission built and installed. I plan on getting a custom 4-5inch mid pipe made to connect to a dual 5 inch mufflers along with my custom 3inch intercooler piping. The transmission I plan on running is a 99 solara E153 with a Quafe LSD and a custom set of one off Drive Shaft Shop 800WHP axels. I am not sure which clutch I am going to run yet and that might depend on sponsorship. I plan on running a AEM to tune this bad boy and have some real fun. You can see pics in my profile and ill try to link a few in this thread. ![]() ![]() ![]() Eazy This post has been edited by eazy2001x: Dec 20, 2012 - 1:15 PM |
OH.. PS.. This project is not going to be finished anytime soon.. I just wanted to feed you guys with some info because you kept asking :-) Ill post progress here.
thanks for coming over, easy.
you can host the pics on photobucket or whatever, and use the img code to post them up. looking foward to watching this build progress!!! -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) ![]() |
HOLY SH!T is what I have to say lol
![]() I am soooooo looking forward to this build! ![]() |
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) ![]() |
welcome to the site easy! I remember your numerous threads on MR2oc years ago about your builds of many, and yes sir you are truly a pioneer. Its good to see you finally on the site man!!
-------------------- (\__/)
Enthusiast ![]() ![]() Joined Mar 8, '10 From Great White North Currently Offline Reputation: 3 (100%) ![]() |
Hey that looks dope!
Thanks Guys… and its ea”Z”y.. I just want to let you guys know that this is going to be a WOP.. This project has already cost me so much money already and will cost me a few more K just to get it all put together. The engine has been done and sitting in crate for like 6 years now, along with the turbo, DB, shifter cables, mounts, 16K used solara transmission and all the other parts. I am trying to get full/part sponsorship for a few items and working with a few companies to get things for free or discounted rates. But so far everything dumped into this project was 100% all my hard earned money.
Things I’m am working on getting sponsored: Quafe LSD Custom Full-Race Traction bar Twin Carbon Clutch setup Light weight race rims/skinnies Slicks Brake setup Front/rear Custom transmission housing / protection guard Custom Axle setup Custom Exhaust (4 inch mid pipe to dual 5 inch mufflers) Fuel system (Cell, lines, pump & filters to mate to my rails) That’s all I can think of for now and will be working on getting all of the above. Wish me luck.. |
join celicatech.com, you can host pictures there for free. and that will be another good source for information
Enthusiast ![]() ![]() Joined Feb 7, '08 From Colorado Springs, CO Currently Offline Reputation: 0 (0%) ![]() |
Eazy, I would like to make a suggestion and not go with the driveshaftshop axles. They are so f-ing expensive its ridiculous. Back when I was going to turbo my Camry, I asked them for e153 axles that supported 600hp and they wanted $2000 for them. Then they went to say that that was the lowest estimate! @_@
You're way better of contacting Josh at Garage CRW. I can't remember which other reputable shop he made a set of axles for, but I believe there's a picture of them in the drag section on MR2oc. They're way thicker all the way through the shaft. -------------------- |
join celicatech.com, you can host pictures there for free. and that will be another good source for information i dont really want to dup info.. im sure most members on there are on here. Eazy, I would like to make a suggestion and not go with the driveshaftshop axles. They are so f-ing expensive its ridiculous. Back when I was going to turbo my Camry, I asked them for e153 axles that supported 600hp and they wanted $2000 for them. Then they went to say that that was the lowest estimate! @_@ You're way better of contacting Josh at Garage CRW. I can't remember which other reputable shop he made a set of axles for, but I believe there's a picture of them in the drag section on MR2oc. They're way thicker all the way through the shaft. I will take a look at them.. the other thing thats good about driveshaftshop is that they will also give me a new hub to press in. I am working with them and we shall see.. I kind of want to measure twice and cut once with this project.. its 6 ears or so in the making thus far and some really talented hands have been involved thus far. |
![]() Enthusiast ![]() Joined Nov 8, '09 From Belgium Currently Offline Reputation: 0 (0%) ![]() |
very nice ^project, looking forward to see updates.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
Glad to have you!
when you get it done i wonder if a mag would take it as a feature. i would love to shoot the car and have a celica grace the cover of a mag. -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
send me a pm with that and ill save it.. i had something in the works and will consider you later on when its done..
Change up on the axle setup.. I am now working with CRW..
I am going to press in the 1991 camry wheel hubs which have 30 spline vs 26 spline. Then use modded Mr2 axles and install them in my celica. They are going to be 300m chromoly from end to end and the half shaft is going to be heat treated along with the rest of the axle parts/hubs/diff. Cost is going to be just about the same and both companies have proven that their products work. |
Enthusiast ![]() ![]() Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
This might be a silly question but I have to ask. Why destroke to 2.1?
oh by the way, your goal might be achievable in the 6th gen world, but in the FWD celica world, you have big hurdals to overcome. Me for one, my 7th gen is making 550 to the wheels and its about to break into 700s when i twin charge it
Grr at the pics being down on my first post.. but here are some pics of the engine with powder coated valve cover, 4 inch down pipe (3 off turbo) and the turbo. sorry for the low quality pics, ill take them over one day.
![]() ![]() ![]() This post has been edited by eazy2001x: Dec 20, 2012 - 1:26 PM |
nice turbo, it looks exactly like my T72 on my Supra
cause thats exactly what it it :-) T72 dual BB Q Trim .84ar.. how much power do you make.. this bad boy is good for 800 to the wheels on a 4 banger.
it made me 700 on my Supra, i ran out of CAM. there was plenty more power to be obtained, but the stock cams were just choking it. plus 700 on a stock engine is pretty hairy. i have heard that the 2JZ can take 800 stock but i wasnt going to push it.
Lo-Fi Version | Time is now: February 17th, 2025 - 3:48 AM |
