> About The Failed Release This Weekend
post Nov 21, 2010 - 8:19 PM
Cliff Notes
The release of the new version of 6GC failed miserably due to bad errors that could not be solved by tonight. I'll be taking a much-needed break tonight and then I'll be working feverishly to find out what went wrong, and fix the problem. Once the problem is fixed, I'll schedule a new release that should take about four hours in the middle of the night. I'll let you guys know in advance before 6GC goes down again for upgrades.
The Long Version
Everything in the release went reasonably well in the beginning. There were some hiccups, but nothing too serious. Then I swapped domains and it all broke.
It's important to note how the release works. Friday during the day, while 6GC was still up, the new version of 6GC was installed on a new hosted server. This server was initially set up to run a different temporary domain name. This gave me the ability to test everything. Then, when everything worked, the plan was to swap IP addresses, which would point the 6gc.net domain to this new server with the new version of 6GC. Everything worked with a small test dataset on the temporary domain just fine, so we were go for release early Saturday morning.
Around 3am Saturday morning, the live site was turned off so that the database and all photos could be copied to the new server. This only took an hour or so.
At this point, the new 6GC was running flawlessly on the new server, which was running with a temporary domain name but all of the posts, information, and photos from 6gc.net. Tests passed and all was well. The last thing to do was swap the 6gc.net domain over, do some last tests of critical components, and then flip my switch to allow everyone else to see the site and not the Twizzlers-promoting maintenance page.
So I swapped the domain over, and then major problems started happening. Most of the problems were configuration issues and were sorted out within a couple hours.
The main problem though, was that file uploads stopped working as soon as the domain was switched over to 6gc.net. Every file upload problem I've had before was pretty easy to solve, but this was not. In fact, I still cannot figure it out, and this is the most stumped I've been in thirteen years of building websites. More technical details can be found on my cry for help at Stack Overflow. If you can help or might know a web dev who knows nginx and HTTP really well (specifically, ask them if they "know how to troubleshoot a HTTP 422 error"), if you could point them to http://stackoverflow.com/questions/4234574...progress-module I'd greatly appreciate it. I'm completely stumped and am about to start digging into the nginx source code (read: painful and slow) to try to figure this out.
Once I can figure out this issue, I think everything else will go well. And then I'll schedule another release. I'm hoping I can get it done before I leave Wednesday for a couple days in Yakima. But it's all dependent on solving that problem. So yeah, I'll post when I know more. kindasad.gif
post Nov 21, 2010 - 8:21 PM
Good luck Christian.
post Nov 21, 2010 - 8:22 PM
mkernz22
Joined May 10, '10
From MA
Good luck man! Take your time with it all
post Nov 21, 2010 - 8:25 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
we have been fine with the forum like this, we can wait for the update, take your time buddy and make it all it can be. best of luck
2001 Solar yellow Lexus IS300
post Nov 21, 2010 - 8:30 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
heh, I guess I need another part my car... so i have to wait for that now... so we can get this figured out!
Good Luck man!
Kevin
post Nov 21, 2010 - 8:38 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Good luck man! Thanks for it all!!
June '12 COTM
'95 AT200
post Nov 21, 2010 - 8:42 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
best of luck!
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Nov 21, 2010 - 9:33 PM
Ted95
Joined Mar 8, '09
From Westport, MA
ya man dont kill your self over it. we are more then willing to give this update time. that your time and get it to the way you want it and do work son! lol we have faith
st205 powered ss3 coupe
post Nov 21, 2010 - 11:01 PM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
coomer you know im your support via facebook! lol.
post Nov 21, 2010 - 11:40 PM
Thanks guys. I'm gonna get some good rest and hit it hard tomorrow. I've got a good feeling about getting this fixed tomorrow once I'm not running on fumes. smile.gif
post Nov 22, 2010 - 3:03 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
cool. thanks for letting us know what happened. I just asked one of my friends if he knows anything about it. I have yet to get a respond to him since it is 12 am here in so cal. I'll let you know if I get any answer from him. I do appreciate your effort best of luck.
post Nov 22, 2010 - 9:09 PM
Bigblock
Joined Feb 14, '09
From Mid West
Coomer--
post Nov 22, 2010 - 11:00 PM
richee3
Joined Jun 29, '08
From Denver
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 23, 2010 - 8:52 PM
zfjohnson07
Joined Apr 11, '09
i came across this
The 422 (Unprocessable Entity) status code means the server
understands the content type of the request entity (hence a
415(Unsupported Media Type) status code is inappropriate), and the
syntax of the request entity is correct (thus a 400 (Bad Request)
status code is inappropriate) but was unable to process the contained
instructions. For example, this error condition may occur if an XML
request body contains well-formed (i.e., syntactically correct), but
semantically erroneous XML instructions.
here is the website for documentation http://www.ruby-forum.com/topic/98002
There's nothing in your code that immediately jumps out at me as wrong. The 422 error means that the account object could not be saved because it was invalid. But typically, there's a body with the response that details the errors. You might try setting the content type to "application/xml" for your request -- I think the server could be trying to interpret your XML as URL encoded form data since it is not specified. The "Accept" header only tells the server what format to output the response -- it says nothing about the request type.
http://support.recurly.com/discussions/sup...unt-create-post
post Nov 26, 2010 - 4:55 PM
No worries mate, All i want is to embed you tube videos
post Dec 1, 2010 - 12:16 PM
Any potential for a mobile friendly version of the site?
post Dec 3, 2010 - 3:32 PM
Perhaps...I'll have to see what's involved in getting the forums to be more mobile-friendly.
And on the topic of releases, I still cannot figure out what's wrong. It's killing me. I'm going to look into alternatives to the previously-working functionality today. kindasad.gif
post Dec 3, 2010 - 5:55 PM
mkernz22
Joined May 10, '10
From MA
With the site as it is right now, it works perfectly on my dad's htc droid, but on my phone I can access everything except for the text fields
post Dec 3, 2010 - 7:23 PM
Rusty
Joined Nov 5, '07
From New Zealand
there is the 'lo-fi version' at the bottom of the page.
I understand that your trying to get the new site up and running, and I'm very grateful that you put up the old/current site back up for now. Just wondering is there any chance of fixing a couple of menus/tabs such as the dropdown menu next to peoples names on the left and the 'options' on the far right (which changes the forum format). However if this slows down the new 6gc site from being completed, dont worry about it.
post Dec 3, 2010 - 9:38 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Rusty @ Dec 3, 2010 - 7:23 PM) *
Lo-Fi Version Time is now: December 3rd, 2024 - 9:54 PM
