Enthusiast Joined Dec 31, '09 From Anguilla Currently Offline Reputation: 0 (0%) ![]() |
Hello Guys I owned A 1994 Toyota Curren ST206. I am in the process of Installing an EMU (emanage ultimate). The car has a gen3 3sge motor in it. I want to know if it would have the same ecu as a 94-97 celica st202 jdm. Just to make sure i have the wiring info correct. I have installed the emanage but the car idles rough. Just wanted to make sure that its not a wiring issue.... Any one with emanage experience feel free to chime in. Please if you have no experience with the ultimate and heard people comment and say its not good please keep that comment to yourself
![]() thx |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
the ecu changed in 95 I think (going by different part numbers) however as far as I can work out it doesn't really mean much. the pin outs for the 3S-GE are the same between curren and celica.
Do you need a diagram of the pinouts? -------------------- |
the ecu changed in 95 I think (going by different part numbers) however as far as I can work out it doesn't really mean much. the pin outs for the 3S-GE are the same between curren and celica. Do you need a diagram of the pinouts? Yes please i kneed to verify that the ecu on the greddy manual is the same one as what i have in the car because it doesnt give you color coding for the wires. I have wired the emanage car starts but it idles rough like a scooby. So i wanna check the wiring. Thanks for your reply. |
![]() ![]() ![]() ![]() I do have larger version of these available. I'm working on finding my pinouts ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) ![]() |
jesus rusty you are the man!
Lo-Fi Version | Time is now: February 18th, 2025 - 4:01 AM |
