stock st205 running 17 psi, How much torque do you think?, if a 3rd gen 3sgte is running 17 psi with a downpipe |
Dec 27, 2010 - 2:56 PM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
looking at getting a clutch... how much torque will a 3rd gen 3sgte have if i have a downpipe and the stock turbo runing at 17 psi? any idea
im trying to decided between a clutch thats rated at thanks a bunch This post has been edited by urbandork: Jan 2, 2011 - 6:39 PM |
Dec 27, 2010 - 3:11 PM |
your gonna need more clutch.
jim made ~250ftlbs, under 17psi, at the wheels. that basicly will put you right at the tq limit for the first one, and just barely under the second. BTW, a quick scan thru the FI dyno sticky is where i got the info. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Dec 27, 2010 - 8:02 PM |
your gonna need more clutch. jim made ~250ftlbs, under 17psi, at the wheels. that basicly will put you right at the tq limit for the first one, and just barely under the second. BTW, a quick scan thru the FI dyno sticky is where i got the info. thanks a bunch ill take a look there |
Lo-Fi Version | Time is now: November 27th, 2024 - 11:54 PM |
