> HELP!!! Rattling noise in the back, As the title says
post Jan 8, 2011 - 2:14 PM
lingham
Joined Jun 9, '06
From Vero Beach Fl.
I have a '98 and '94 Celica GT. I bought the '94 2 years ago and it had a slight rattle which comes from the back area. It has gotten worse lately and even though it sounds like it's coming from inside, I can't find what is causing it. My '98 has started with the same sound just recently. I've had the suspension and under side of both cars checked by my mechanic. All is in order underneath with nothing loose. The suspension and exhaust systems on both cars are solid. Has anyone had a similar problem and found the cause/solution?
Thanks in advance.
My wife's '94 is starting to make the same noise. Her car is a GT coupe with only 64,000 miles on it. It is not as loud or noticeable as mine is.
This post has been edited by lingham: Jan 17, 2011 - 12:23 PM
post Jan 8, 2011 - 4:33 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
look to see if your license plate it tight. mine wasnt and made the worst rattles ever!!!
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Jan 8, 2011 - 10:01 PM
playboymma
Joined Jan 7, '11
From Mena, AR
my 94 gt hatchback is doing it now. its the rear strut assembly. when the rubber seal ruptures you lose all your fluid in your shock and it rattles like its about to fall off and a lot of mechanics dont test properly for a dry shock. go to the back of your car and bounce it up and down a bit, get it really bouncing, and then just back away. if it immediately stops then your struts are fine and you have some other problem but if it keeps bouncing you have dry struts. most autozones have bilstein rear struts for around 150... and they are worth it a friend put the bilsteins on his car and the rattling stopped. when i can afford it im doing the same
I went full retard once, too. Its OK.
post Jan 8, 2011 - 10:33 PM
mkernz22
Joined May 10, '10
From MA
i hear that rattle every once in a while when im driving slow, but never when im going fast.
I probably have the same problem
post Jan 8, 2011 - 11:43 PM
playboymma
Joined Jan 7, '11
From Mena, AR
its not fun cuz at any speed over highway speed limit the back end likes to hop when you hit a rough spot in the road. ESPECIALLY if youre going through a corner at a decent pace
post Jan 9, 2011 - 1:36 AM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
if its sounds like really loud and constant road noise, its the spindles... that being said, the spindles arent a crucial part that needs to b replaced, but if u have the money go ahead and check into that.. they r about $90 a piece depending on brand
post Jan 9, 2011 - 3:24 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
Wat does it sound like?Metal hitting metal or what?How many miles are one both of your cars? Blown rear struts will make noise at slow speeds when you hit little bumps in the road.
post Jan 10, 2011 - 1:35 PM
lingham
Joined Jun 9, '06
From Vero Beach Fl.
QUOTE (SupraKid @ Jan 9, 2011 - 3:24 AM) *
Milage is '94=125,000 '98=135,000. When I bounce both cars, they stop right away, It doesn't sound like metal on metal. It's more like a wooden clunking sound. In both cars the noise seems to be coming from the passenger rear. The noise is most noticeable at slow speeds. At highway speeds on a smooth road there is no noise.
post Jan 10, 2011 - 3:40 PM
playboymma
Joined Jan 7, '11
From Mena, AR
sounds like a spindle then. best bet is ebay
post Jan 12, 2011 - 12:15 PM
lingham
Joined Jun 9, '06
From Vero Beach Fl.
QUOTE (playboymma @ Jan 10, 2011 - 4:40 PM) *
With the car up on a rack we have tried to shake the suspension and there is nothing loose and no noise. It doesn't seem to be anything the suspension or chase. It sounds liken it is coming from inside the car. I took out the jack, spare tire, and everything from the rear of the car and it's still there.
post Jan 12, 2011 - 5:22 PM
playboymma
Joined Jan 7, '11
From Mena, AR
QUOTE (lingham @ Jan 12, 2011 - 1:15 PM) *
try pulling the panels out of the cargo area
post Jan 13, 2011 - 12:03 PM
EKAn
Joined Apr 24, '07
From CA
Maybe your gas tank is loose or exhaust system could be missing a hanger or something?
what hes saying is if you put blue lights in you car youll lose hp.
post Jan 13, 2011 - 2:27 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
spindles arent really noticeable unless you pull everything apart and try spinning them like bearings... plastic could b loose, but there has to b something making them rattle. spindles can and will make interior panels vibrate, which leads to what u are likely hearing. without something causing them to vibrate, the panels wont make any noise.
post Jan 13, 2011 - 4:44 PM
playboymma
Joined Jan 7, '11
From Mena, AR
QUOTE (d3ath2009 @ Jan 13, 2011 - 2:27 PM) *
of course the panels themselves wouldnt vibrate but if there's something behind them it might. thats the only reason to take the panels out
post Jan 18, 2011 - 1:08 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Try checking the exhaust hanger closest to the passenger side on the muffler. My bushing there is going out and it rattles like I've got loose change sitting on a sub. lol
It won't show up unless you get under there and physically move the bushing. It made no noise when I tried shaking the muffler/pipes.
~bloodMoney
post Jan 18, 2011 - 7:29 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I know it sounds odd, but how are your rear seats (upper portion). I had a similar issue and it was driving me nuts....but yesterday when I was in the back seat cleaning the window i leaned up against the rear seat (upper) and it was sorta loose, like the latch was catching a bit....so I unlatched, and slammed the seats in....no rattle/squeak....
post Jan 18, 2011 - 8:25 PM
barterj
Joined Aug 28, '08
From Woolwich, Maine
Check the spare tire, i know it sounds odd, but mine was loose and would rattle around, also as suggested above, pull the interior panels and make sure nothing has come loose behind them, maybe a loose speaker mount? loose power antenna? rattling generally means something is loose somewhere.
post Jan 20, 2011 - 4:09 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
good luck man, chasing noises is a b*tch.
Mike W
269awhp / 273ft-lbs
post Jan 20, 2011 - 5:29 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
I have the same noise, rear passenger side. Very low rpm rattle, high rpms/high speed no rattle. I would be willing to bet it's your bumper rattling against 1 of a few things: Muffler, Bumper Bracket, pretty much anything it touches. So, try checking your bumper once and see if it's hitting anything.
post Jan 20, 2011 - 6:05 PM
lingham
Joined Jun 9, '06
From Vero Beach Fl.
QUOTE (cyberblader1130 @ Jan 20, 2011 - 6:29 PM) *
Thanks for the tip but thats not it. Everything is solid both underneath and the bumper shows no movement at all. The exhaust system and everything else is rock solid. Did fixing your loose bumper cure the problem? What you are describing sounds like what I have.
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 12th, 2025 - 11:04 AM
