> FS: E153 FWD conversion parts
post Mar 25, 2011 - 5:42 PM
Vip09
Joined Sep 25, '07
From Mobile, AL
All parts are from an ST185 Alltrac. $75 shipped.
2001 GT-S 6speed and 1992 turbo All-trac
post Mar 30, 2011 - 2:06 PM
Vip09
Joined Sep 25, '07
From Mobile, AL
Still available.
post Apr 6, 2011 - 1:16 PM
hesed77
Joined Apr 14, '06
From Chattanooga, TN
QUOTE (Vip09 @ Mar 25, 2011 - 6:42 PM) *
Do I need to do some drilling in the cast of the tranny? What kind of shifter cables should I use?
post Apr 14, 2011 - 10:31 AM
Vip09
Joined Sep 25, '07
From Mobile, AL
Here is what I found with a quick search.
QUOTE (presure2 @ Dec 20, 2008 - 9:41 AM) *
converting to FWD is easy.
on the tranny, there are 4 bolts that hold a cover on where the selector would normally go in a FWD situation, you remove that cover, the 2 plugs on the top of the tranny (one is a fill bolt, the other is a breather vent), remove the 2nd shift lever that attaches to the tranny with 2 bolts. then pull the mr2 gear selector arm out of the tranny. (make sure the tranny is in neutral when you do it.)
then, the FWD selector goes in where the cover plate was, the 2 top plugs go in, and you will have to drill 2 holes for the other shifter arm (the spots are there for them, you just have to drill and tap them)
for the speedo sensor, you just need a electronic speedo sensor from a 93+e153. no big whoop. jdm, usdm, it shouldnt matter, all it does is send a pulse to the ecu.
as far as mounts, and cables, you NEED the 205 rear mount, and shifter cables, dont let anyone else tell you otherwise.
it wont shift properlly without them.
post Apr 15, 2011 - 11:41 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
stilll have the trans? i might need the output shaft.
nvm diff p/n
post Apr 18, 2011 - 11:43 PM
Vip09
Joined Sep 25, '07
From Mobile, AL
Bump, still have these parts.
post May 28, 2011 - 1:42 PM
toyotatech3
Joined Jul 30, '04
From colorado
do you still have these parts?
Lo-Fi Version Time is now: November 27th, 2024 - 8:05 PM
