ABS Codes 11-21-32-35 |
Mar 27, 2011 - 11:05 PM |
Enthusiast Joined Oct 16, '07 From Seattle Currently Offline Reputation: 15 (100%) |
got these codes from the abs. 11-21-32-35 Whats needed to fix them?
Mar 28, 2011 - 12:19 AM |
Code 11
Open in solenoid relay circuit. Check actuator wiring harness, solenoid relay, solenoid relay wiring harness and solenoid relay connector. See SOLENOID RELAY under COMPONENT TESTING. Code 21 Open or short circuit in solenoid for right front wheel. Check actuator solenoid, wiring harness and connector. See ACTUATOR CHECK under DIAGNOSIS & TESTING. See ABS ACTUATOR under COMPONENT TESTING. Code 32 Malfunction of left front wheel speed sensor signal. Check speed sensor, sensor rotor, wiring harness and connector. See SPEED SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See FRONT SPEED SENSORS under COMPONENT TESTING. Code 35 Open in left front or right rear wheel speed sensor circuit. Check speed sensor, sensor rotor, wiring harness and connector. See SPEED SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See appropriate speed sensor testing under COMPONENT TESTING. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Lo-Fi Version | Time is now: January 10th, 2025 - 5:46 AM |
