Quick fuel filter question |
May 7, 2011 - 10:39 AM |
Enthusiast Joined Jun 10, '10 From Fredericton, New Brunswick, Canada Currently Offline Reputation: 0 (0%) |
Hey, just took a peek at toyodiy to get some parts numbers and noticed that the fuel filter part number for a 94 GT4 and a GT are listed as being the same: 23300-79425.
Can anyone confirm that before I head to the local toyota dealer to order up some maintenance parts? It'd be nice if I didnt have to order it from teh internetz |
May 7, 2011 - 11:54 AM |
Enthusiast Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
i think u dont need to change ur kind of fuel filter, im not 100% sure, but i think u only need to change it when u go more than 600-700 hp
i did buy the same filter for my 3sgte as for my 94 gt-s but i didnt try it myself yet This post has been edited by Needles: May 7, 2011 - 11:54 AM |
May 7, 2011 - 6:23 PM |
Enthusiast Joined Feb 5, '09 From New Zealand Currently Offline Reputation: 0 (0%) |
I think he's changing it because they get clogged after time, as they are filtering crap out of your fuel. Not sure of part numbers but the one I had in my St202 looks the same as the one in my ST205.
I think the fuel pumps are the same so the flow will be similar therefore the filter should be able to handle both. As needles said you shouldn't need anything bugger till 600-700hp. Although the next time I work on my fuel system, i'll prob install a shiny aftermarket filter with AN fittings, will help tidy up the engine bay too. |
May 7, 2011 - 9:36 PM |
haha yeah I'm just changing it as a maintenance thing, im about to order a few odds and ends from the toyota dealer here and the fuel filter was the only thing I wasn't totally sure was the same. Also going to get a new cap/rotor and a valve cover gasket too as mine is leaking.
May 7, 2011 - 11:17 PM |
I think he's changing it because they get clogged after time, as they are filtering crap out of your fuel. Not sure of part numbers but the one I had in my St202 looks the same as the one in my ST205. I think the fuel pumps are the same so the flow will be similar therefore the filter should be able to handle both. As needles said you shouldn't need anything bugger till 600-700hp. Although the next time I work on my fuel system, i'll prob install a shiny aftermarket filter with AN fittings, will help tidy up the engine bay too. fuel pump are different, st205 throw more fuel |
Lo-Fi Version | Time is now: December 4th, 2024 - 2:33 AM |
