new clutch |
new clutch |
May 8, 2011 - 7:44 PM |
Enthusiast Joined Nov 29, '07 From california, marysville Currently Offline Reputation: 0 (0%) |
clutch went out... i was just wondering whats the best or better brand out their for the 5sfe?
May 8, 2011 - 9:40 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
If you're planning to keep the motor relatively stock, I'd go with an OEM toyota clutch if you can afford it.
If not I'd get an exdy OEM replacement, which is slightly cheaper than an OEM. I just put a new OEM clutch in my car. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
May 9, 2011 - 11:01 AM |
^^^ cant argue with this. if you want a slightly upgraded clutch, i suggest Southbend clutch. they are fantastic and have incredible customer support if you need it.
May 9, 2011 - 11:39 AM |
Enthusiast Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
As said above. If car is not modified and money is not an issue, go with OEM. Clutch labor is not cheap and if u do it yourself its time consuming. Otherwise, I had some luck with exedy and ACT.
-------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
May 9, 2011 - 11:50 AM |
It only takes about a day to do the clutch (if you know what you're doing) haha but to have a shop do it, it costs quite a bitttt
May 12, 2011 - 10:57 PM |
i'm just doing it myself... the tranny's out already....its not the first time..... but thanks for the info
Lo-Fi Version | Time is now: December 4th, 2024 - 4:23 AM |
