> Converting E154f to fwd, anyone actually done it?
post Jun 13, 2011 - 10:46 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
So been doing some searching and found a site that shows how to convert the e154f to fwd, using mr2 diff and cover plate.
has anyone on here actually done this? im quiet interested in doing this conversion to keep the low mileage tranny that came with the clip, and no this will not burn the diff up since it will be swapped.
or any thoughts on this?
2001 Solar yellow Lexus IS300
post Jun 13, 2011 - 11:25 PM
yes, i posted this topic a while ago and culpable responded... i cant find the thread.
found it
http://www.6gc.net/forums/index.php?showto...37&hl=e154f
post Jun 16, 2011 - 2:47 PM
czwalga
Joined Sep 27, '10
From pittsburgh
I'd be interested in buying the e154f if you dont end up converting it.
-10 F150
post Jun 16, 2011 - 5:14 PM
Culpable04
Joined Apr 17, '06
From New Jersey
as I posted before, it's perfectly doable, my big mistake was trying to rush things. I would adivse you to start the tranny conversion before you start working on the engine, so you dont get the feeling of the trans holding you up and rushing through it ( that's what I did ) and dont cheap out, by the proper tools, it'll make a world of difference.
as I said on my PM I have the parts you need, so let me know if you want them.
post Aug 8, 2011 - 7:09 PM
LimitedGT4
Joined Apr 18, '11
From Southern Alabama
culp,
would you be interested in helping me attempt this conversion or possibly do it for me for a fee, as ill need a new tranny and i would rather use my e154f
please let me know
post Aug 12, 2011 - 8:30 PM
LimitedGT4
Joined Apr 18, '11
so im trying to take apart my e154f tranny and it doesnt seem to come apart and am not sure but i believe i need to take some bolts out if some one knows and wants to help me, please let me know
soo these bolts on the first 2 pics do they need to come off im guessing yes
or do i just nee to take it apart like in this third pic?
didnt want to just yank it it apart and break sumtin
dont need retarded "sarcastic" (that only makes you laugh) commentary
or if some one has a diagram or manual that explains the process even better
LINKS ARE WELCOMED AS WELL AS SEARCH HINTS
This post has been edited by LimitedGT4: Aug 12, 2011 - 8:52 PM
post Aug 13, 2011 - 9:52 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
5th gear has to come off. then the brass bolts come out ad then that case can come off
post Aug 13, 2011 - 10:14 PM
enderswift
Joined Jul 12, '08
http://www.ae92gts.com/ae92gts_trans_rb_1.html
read this. Its VERY helpful. Its a c52, but the two transmissions are similar enough that its a very good guide. You have the factory manual right?
This post has been edited by enderswift: Aug 13, 2011 - 10:15 PM
post Aug 18, 2011 - 11:58 AM
Culpable04
Joined Apr 17, '06
From New Jersey
there is a " cheat " way of doing this,
you jsut need to separate the bell housing,, basically undo all the bolts holding the bell housing in place ( as you did ) then with a flashlight, look inside the small opening, look for a metal peice attached to the bell housing by 2 10 or 12 mm bolts, undo those bolts and the bell housing will come off, now, remove the diff and replace it with a LSD diffent and re install the bell housing,, then re do the metal piece again ( this is tought and takes time ) you have to install the peice back again the way it was, and secure it through the small opening, then close the trasn, spin the shaft to make sure everything is aling ( while in neutral ) is everything checks out, close your trans. follow proper bolting techiniques and don't over torque the bolts, make sure the case is closing evenly ( that was my mistake ) and dont forget the magnet, you can easily lose it as it will fall off once the bell housing is separated.
Lo-Fi Version Time is now: February 21st, 2025 - 5:34 PM
