vacuum pipe |
vacuum pipe |
Jul 17, 2011 - 2:52 PM |
Enthusiast Joined Nov 2, '06 From Finland Currently Offline Reputation: 0 (0%) |
Hi! Can somebody help me?
where do i put this pipe? a pic would be nice |
Jul 17, 2011 - 5:15 PM |
Enthusiast Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
Where is it coming from?
-------------------- (\__/)
Jul 17, 2011 - 5:52 PM |
If thats the vac line from the FPR then theres a port for it to the left of the TB
Why did you replace all your hoses? what's that Tee for that you put into your charcoal canister line -------------------- Mike W
Jul 17, 2011 - 11:07 PM |
Its coming from throttle body. red circle.
Replaced all hoses because im looking a vacuum leak. the tee is for my turbo pressure gauge, did i put it in a wrong place?? |
Jul 19, 2011 - 1:03 PM |
somebody? help me out
Jul 19, 2011 - 1:21 PM |
Goes to the charcoal canister
This post has been edited by 3WayStunna: Jul 19, 2011 - 1:22 PM -------------------- (\__/)
Jul 19, 2011 - 1:41 PM |
ok thanks so i can just leave it hanging around
Jul 19, 2011 - 1:55 PM |
EDIT: do you plan on getting rid of your charcoal canister? If YES, then cap it off and ditch the charcoal canister...But you will probably deal with the smell of gas or maybe fuel vapors in and around the engine bay....
And you would also need to cap off that port on the throttlebody.... If not you would probably want to cap off both ends ( TB side/CC side) although i personally dont know how that would affect your engine...i would just route it through as it naturally would, as it isnt really a big deal. This post has been edited by 3WayStunna: Jul 19, 2011 - 1:58 PM -------------------- (\__/)
Jul 19, 2011 - 2:12 PM |
Well. it just fell off when i was doing something under the bonnet and did not find a place where to put it back.
where is this cc located? |
Jul 19, 2011 - 7:13 PM |
The charcoal canister is located as follows. Looking at the engine from the front of the car, it would be on the right hand side of the engine bay. Would be near where the fuel filter is located. If its not connected up right now, might explain your boost leak/vacuum issues.
Lo-Fi Version | Time is now: January 11th, 2025 - 10:49 AM |
