hesitation and loss of power (no more), problem solved, thanks.... |
Jul 29, 2011 - 4:05 PM |
the swap is only 1 year and 5 months old, and only 500 miles since the swap.
the car has not been driven a lot the last 7 months. It almost went on a empty tank of gas. Long story short, about two weeks ago decided to daily drive it again. The hesitation was new, but i took the maf out and exchanged it for another one, and added fresh gas to the tank, the hesitation went away. I have been out of the country for about 10 days. I came to drive the car and the hesitation is now back. At first, (two weeks ago) It was not all the time, its like suddenly lost power to one cylinder and then it came back. Difficult to explain. I use to give it gas and then it was better. but today its most of the time, but it disappears for a few seconds. I know there is nothing wrong with the engine compression, but im concerned of course with : 1. Injector clogged 2. Vaccum leak 3. Bad sparks 4. bad maf This engine used to purr like a kitten, but im afraid its lack of use may have caused this. I have a can of seafoam ready to use, before i start taking the route of cleaning the injectors profesionally and wasting money. here are some videos.. car is at idle:shocked: http://www.youtube.com/watch?v=I0LC_euE7pg driving slow in the street, i try to give it some gas to clean the obstruction, so that's me accelerating, the car does not do that. Just bogs down...:tear: http://www.youtube.com/watch?v=fugSnfmqS30 Should i just seafoam it or where do you guys send your injectors if that seems to be the problem... This post has been edited by njccmd2002: Jul 31, 2011 - 6:10 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jul 30, 2011 - 12:04 PM |
Enthusiast Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
start simple. do plugs wires and the cap and rotor. sounds like a standard misfire to me
Jul 30, 2011 - 12:35 PM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
I had a similar problem way back, mine would pop and bog during regular acceleration and even at a constant speed at 65 when I was on the highway. It was kind of whenever too - didn't do it all the time. Anyway, I pushed in all the plugs at the dist. cap one day after a buddy made the suggestion and it had no prob whatsoever after that for several days. Then, it started doing it again so I replaced the cap and plugs and wires - solved the problem.
This post has been edited by 6G96GT: Jul 30, 2011 - 12:35 PM |
Jul 30, 2011 - 12:38 PM |
Enthusiast Joined Jun 7, '11 From so cal Currently Offline Reputation: 0 (0%) |
yeah sounds like a missfire, it sounds like it does it in the lower rpm band, check those cables,
Jul 30, 2011 - 1:32 PM |
thanks for the responses, but i have no rotor or plug wires, lol.
failed to mention its a 3s-ge beams with coil packs... but yes, will check the coil packs, and sparks first, then go ahead and do the injectors and throttle cleaning later.. the only thing i have done bad is not running it frequently, so i suspect gum in the injector. but dang i have to remove so much to work on it!!! oh well. ill keep posted... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jul 30, 2011 - 1:41 PM |
I dont think the injectors will gum up from a few months of non-use. if u have like a quarter tank of gas u can try pouring a can of seafoam in there and running it till its almost empty, to clean them up.
Pull the COP and check u have a bright blue spark, if so theyre fine. I would start with spark plugs though -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 30, 2011 - 2:28 PM |
change your plugs.
Jul 30, 2011 - 3:03 PM |
Enthusiast Joined Apr 22, '09 From Work Currently Offline Reputation: 2 (100%) |
Looks like low compression or a vac leak to me I'm hoping you did replace the spark plugs when you did the motor swap ??
-------------------- **If you can read this you are too close**
Jul 31, 2011 - 6:16 PM |
went and got new sparks today and cleaned all the contacts to the coils, amazing....
old sparks were not that bad... thanks for all the troubleshooting done here... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jul 31, 2011 - 7:04 PM |
solved correct ?
Jul 31, 2011 - 8:14 PM |
yes, it purrs.. now... thanks..
Jul 31, 2011 - 8:57 PM |
Good to know. I picked up new plugs already but I'll clean my contacts tomorrow. They were covered in oil, after all.
Lo-Fi Version | Time is now: January 9th, 2025 - 9:57 PM |
