> 3rd Gen 3SGTE Stock ECUvs MR2 EECU, had a talk with a guy today.
post Aug 22, 2011 - 5:40 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
Hey everyone,
so in Dire need of a flywheel, fate decided to get me in touch with a All Trac owner who had an extra flywheel. he has put in a 3rd Gen 3sgte in his all trac and loves the hell out of it. he was telling me though that I should be getting a CEL because of the ECU not seeing the water pimp for the intercooler... and this would bog down the system and the car would lacking in performance. he also stated that because he bought a 3rd gen MR2 edu his boost leveled out at about 18PSI (now is 22PSI)
I DO only get 12-14 PSI from my Turbo, but I don't have a CEL. never did, I don't know if thats because I routed the waterpump to just come on when the car power came on or the Wiring Harness Tweak'd did.
has anyone else heard of this before? I'm curious to know. he did offer to put the MR2 ECU in my car to show me the differance (which I intend to do when I get my car back and put in a new flywheel and clutch)
Thanks
Kevin
post Aug 23, 2011 - 12:36 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
if you did the resistor mod for it then it would not throw the CEL. if you are not getting it and you got your harness from tweak he probably took care of it for you. i cant guarantee that tho. also not sure if he is running 22psi on a stock ecu because the fuel cut is just over 17. he could run an FCD but they dont work correctly on a MAP sensor setup they make the ecu think its at max boost all the time.
post Aug 23, 2011 - 10:58 PM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
I'm confused...what ecu are you running in your car? Like ST205WRC said, fuel cut on a celica gen3 (st205) ecu is around 17psi. I think the mr2 version is different...maybe not. I have a st205 ecu for sale if you're interested smile.gif
post Aug 24, 2011 - 2:37 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
i used to run my stock ecu and turbo 205 on 20 psi without hitting fuel cut, and i know the map sensors dont max out till 22-24.
GRX133 Toyota Mark X 350s
post Aug 24, 2011 - 4:06 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
I am running a stock ST205 ECU.
however, the guy who I talked to has an MR2 Stock ecu in his. he has a Boost controller so that's, (assuming here) how he is managing the 22PSI I believe.
he told me that the ST205 ECU, if it can't find the water pump in the system, it will bog down the performance of the car, only letting it boost around 12-14PSI. while the MR2 (not having the pump) ECU will allow you to boost to the 'stock' 17-18 PSI. though it comes with a -10 HP cost.
if this is the case, I'll probably will be switching out the ECU soon-ish. if no one else here can confirm this then I will probably take him up on his offer to put his ecu in my car. and Ill test it...
Kevin
post Aug 24, 2011 - 5:25 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
if it doesnt see the pump then it will produce code 54 and the check engine light will come on.
post Sep 24, 2011 - 11:06 PM
injection
Joined Jan 10, '11
From Trail BC
I know im a little late here but Teak did my wiringv harness, and for some reason tried the mod to eliminate the IC pump, and it never worked, I now have my check engine light on, and is a code 54, but, for some reason, don know why...Im hittin 18lbs of boost, very quickly!, and top side of 16lbs in 4th and 5th gear.....I know! weird,
post Sep 25, 2011 - 1:28 AM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
I have a FCD installed and my ECU reads boost quite fine...and drops down after you let off throttle I thought the whole point of the FCD was to disperse voltage to chassis lowering the signal to borderline fuel cut and keep the fuel coming...
post Oct 18, 2011 - 5:10 AM
MaicoOens
Joined Oct 18, '11
From USA
post Oct 19, 2011 - 2:38 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
ive installed a FMIC on my st205, i removed the pump. I looped the charge cooler plug and now im running fine. Therez a lot of explanations of how to cure error code 54 on the net.
post Oct 30, 2011 - 9:52 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
QUOTE (MaicoOens @ Oct 18, 2011 - 5:10 AM) *
ST205 stock boost 11psi-first gear 13psi-second gear-fifth gear, when st205 ecu is on code 54 it runs between 10psi-11psi and runs quite rich bogging performance. 17-18psi 0.o not stock
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
Lo-Fi Version Time is now: November 24th, 2024 - 4:57 AM
