> 94 celica gt (celicaNT)
post Aug 28, 2011 - 2:51 PM
vogler
Joined Aug 17, '11
From Galesburg Illinois
[size="3"][font="Arial Black"]hey guys my names Jake i just bought a 1994 celica gt drove it home and it over heated and then realized it leaked more oil then you can put in it...i like the car alot so im gona start working on it im gona replace all the gaskets new clutch and maybe a header for now just to get it to driving condition i will try to keep posting pictures of the progress i will post pics if i can figure out how
This post has been edited by vogler: Aug 28, 2011 - 2:53 PM
post Aug 28, 2011 - 3:04 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
you can wash the engine bay to figure out where the oil leak is.
check your coolant level and see if its just low on coolant causing the overheat
post Aug 29, 2011 - 10:36 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
I hope it's not a warped head. Are you smoking?
post Aug 31, 2011 - 12:37 AM
vogler
Joined Aug 17, '11
the only thing i seen smoking was the radiator cap the guy i bought it from bought it with a bad radiator and put one in from the front clip he ordered from japan the car was probably ran hot if the radiator was bad would that cause the head to warp? the thermostat is good i think the waterpump is good because there was coolant in the head when i took the housing off my luck its probably the head or headgasket
Lo-Fi Version Time is now: November 28th, 2024 - 12:36 AM
