> which Wideband O2 sensor for a 3S-GTE?
post Aug 29, 2011 - 9:14 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
Hey everyone,
So Berk Tech were kind enough to work with me and send me a new downpipe then refund my money once they get my old one. on top of that, they were also nice enough to 'upgrade' me to a wideband downpipe. (something I wanted to eventually do anyway) however, I really don't know what I need to do.
My searches have come up with
"its kinda plug and play. remove the narrow and plug in the wideband in the same place" (excluding gauge wiring)and
"you have to buy the sensor, and a controller" (both ways need the gauge)
the plug and play, while I really wish it was, sounds like it doesn't actually get you the information you need. I'm not sure what sensor/system i should get...
any tips?
Kevin
post Aug 29, 2011 - 9:16 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
you can get a LM1 wide band or a AEM UEGO wideband.
i know the AEM threads into a stock O2 place cause i recently did just that on my 100% stock 7a lol
post Aug 29, 2011 - 9:20 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (stephen_lee @ Aug 29, 2011 - 7:16 PM) *
now is that the AEM kit? meaning the controller?
and does that mean I have to get a bung so it goes to the wideband hole on the Berk Downpipe?
Kevin
post Aug 29, 2011 - 9:30 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its an AEM kit, sensor and controller. they come with a bung so you just need someone who can weld, worst case
post Aug 29, 2011 - 11:26 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
I was hoping I wasn't going to need a kit... haha I don't like wiring stuff
post Aug 30, 2011 - 8:48 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its pretty simple. you give the gauge power and ground, and hook one wire to where the stock o2 sensor went, and set the controller to emulate a narrowband.
its in the instructions, easy to follow
post Aug 30, 2011 - 2:07 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
Should I buy the one for the 2nd gen 3sgte?
post Sep 7, 2011 - 11:19 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
whoooo! installed the O2 Sensor... it only took 2 hours... haha
though, is 14.8 okay? I think it might be on the lean side... not sure haha
Kevin
post Sep 7, 2011 - 6:00 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
thats ok for cruise idle and off boost. 12-13 is ok for boost
post Sep 13, 2011 - 1:16 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (stephen_lee @ Sep 7, 2011 - 4:00 PM) *
I think it's busted, it doesn't move... when the key is in the on position but without turning the key actually on it still reads 14.8 then turn the car it doesn't change, nor while driving :\
post Sep 13, 2011 - 4:10 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
they show that when the sensor isnt plugged in lol...
post Sep 14, 2011 - 12:32 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (stephen_lee @ Sep 13, 2011 - 2:10 PM) *
lol yeaaah, I had everything wired and plugged in... I was checking my other gauges and so I checked that one too. I fumbled it and it fell out of my hand, and the sensor plug fell out. I looked at it and in the back and two of the prongs were bent up... fixed that and now it is going back and for like crazy as I drive.
Kevin
post Sep 14, 2011 - 12:36 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
thats normal. mine does it too
the only times I have a relatively stable reading is warm up idle, and WOT
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 24th, 2025 - 2:35 AM
