e154f and e150f |
e154f and e150f |
Sep 8, 2011 - 6:52 PM |
Enthusiast Joined Aug 8, '11 From new windsor, new york Currently Offline Reputation: 2 (100%) |
what is the difference between the two transmissions one is from an st205 and the other is from an st215 they are both awd so what is different from them
Sep 8, 2011 - 8:23 PM |
Enthusiast Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
The 205 box is the pinnacle of GT-four transmissions with its duel cone synchros etc. The e151f is the same as (some) of the ST185 boxes.
A friend of mine has a Caldina here in aus and she is going through the process of trying to change driveshafts. Apparently they are different inners and outers then any GT-four. So her only option if she wants a gearbox upgrade is to use the inner cvs that match the gearbox and outer cvs that match the hub. Im not sure if hers is a 150f though, ill have to ask her again and get back to you. This post has been edited by Cuts_the_Pilot: Sep 19, 2011 - 1:50 AM -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s |
Sep 10, 2011 - 1:40 PM |
The 205 box is the pinnacle of GT-four transmissions with its duel cone synchros etc. The e150f is the same as (some) of the ST185 boxes. A friend of mine has a Caldina here in aus and she is going through the process of trying to change driveshafts. Apparently they are different inners and outers then any GT-four. So her only option if she wants a gearbox upgrade is to use the inner cvs that match the gearbox and outer cvs that match the hub. Im not sure if hers is a 150f though, ill have to ask her again and get back to you. thanks for the help i really appreciate |
Lo-Fi Version | Time is now: November 27th, 2024 - 6:36 PM |
