Enthusiast Joined Oct 14, '11 From gig harbor wa Currently Offline Reputation: 0 (0%) ![]() |
I'm beginning the swap and I'm not sure what needs to happen as far as wiring goes when I go to install.
So here are my questions: 1: Should I pull both harnesses, and get ahold of someone to wire them together? or 2: Is is possible to simply cut a hole in the firewall to feed the harness from the 3sgte to the ecu (3sgte ecu of course) and would that work with the rest of the car? Like I said, I've searched and haven't been able to find a solid answer. Here's a teaser I took a couple days ago. ![]() ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) ![]() |
I'm beginning the swap and I'm not sure what needs to happen as far as wiring goes when I go to install. So here are my questions: 1: Should I pull both harnesses, and get ahold of someone to wire them together? or 2: Is is possible to simply cut a hole in the firewall to feed the harness from the 3sgte to the ecu (3sgte ecu of course) and would that work with the rest of the car? Like I said, I've searched and haven't been able to find a solid answer. Here's a teaser I took a couple days ago. ![]() ![]() 1-its your choice but for myself , no. dont pull out the harnesse, cut your hole in firewall before u put the engine in, or you can extend the wire, the only thing is the ea1 plug , do search, and make your choice from there, some ppl do that diffentetly and its also works 2- yes |
Shoot... I alrighty have the harness out for the most part...
but thank you for the answer! This post has been edited by justincapps94: Oct 20, 2011 - 5:28 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) ![]() |
its alot easier to cut a hole in the bottom of the fire wall rather then extending every single wire in the harness.
this thread will show you what you have to do to your harness to get it swapped properly your self. http://www.6gc.net/forums/index.php?showto...3105&st=140 its a VERY detailed thread that will answer just about any question you might have along the way, look through it a couple times it will help. and there are plenty of guys on here who can help as well, myself included. goodluck dude! -------------------- st205 powered ss3 coupe
Thank you needles and ted, this is helping so much. I feel completely confident about the wiring!
another pic to keep ya guys looking ![]() ![]() |
i think you just add the wrong pic there l;ol.....
Oops needles your right, I'm at work but tonight I'm gunna start a build thread
Lo-Fi Version | Time is now: February 21st, 2025 - 3:55 PM |
