> 5SFTE project, got a few questions
post Oct 28, 2011 - 12:00 PM
batcavee00
Joined Sep 22, '10
From pomona, ca
hey whats up guys, im in the process of turbo charging my 94 gt. everything is pretty much stock. i just rebuild the whole engine and ported and polished the head. i got all my parts ready, just had a few questions here they are:
i got some rx7 460cc injectors: are these too big, if im just gonna run about 10psi?
i was also looking to buy a water/meth injection kit, will this benefit me if again, im running about 10 psi?
i was also thinking of getting something to control the ignition timing ( MSD BTM), do i really need it " " " " " "?
lastly, is it safe to run more than 10 psi on the stock block with the above components?
any input/ recommendations is greatly appreciated =]
my set-up:
460cc rx7 injectors
26x12x3 FMIC/ 2.75" piping
generic t3t4 turbo, trim .50, a/r .63
SSBOV
AEM wideband 02
stock fuel pump
post Oct 28, 2011 - 5:01 PM
QUOTE (batcavee00 @ Oct 28, 2011 - 1:00 PM) *
your gonna need somthing to tune with anyway, so no. [b]
[b]
yes.
no, although as you up the boost, with a unit like the emanage ultimate can control timing, fuel, and a bunch of other stuff as well
supershannon77 has a great build thread that use the same turbo. she made ~240whp @ ~11.5 psi, and ~ 285whp @almost 17psi.
tuning was done with an SAFCII or Neo, i cant remember, its been that long..lol its prolly in the thread.
you will kill the motor with the stock fuel pump. a walbro is cheap (100 or less), and pretty easy to install. get a foam sock for it, and it actually wont even be loud, like most people talk about.
check out this thread that basicly takes you thru her whole build.
http://www.6gc.net/forums/index.php?showtopic=52431&hl=
good luck.
my set-up:
460cc rx7 injectors
SSBOV
AEM wideband 02
stock fuel pump
post Nov 2, 2011 - 4:53 PM
batcavee00
Joined Sep 22, '10
From pomona, ca
thanks for all that info!
made a bit more research, but i dont want to get the emanage right now.
will i be ok to just use the SAFCII to control the injectors?
i called a local tuner and he said if we use the SAFCII i would only be able to run about 8psi with my set-up and that my injectors would almost be maxed out, is that true?
post Nov 3, 2011 - 8:54 AM
not with the 460's those are big enough to run about 12 psi
post Nov 3, 2011 - 1:49 PM
You obviously didn't read the thread I linked.
I ran almost 17psi, controlled by an safc on shannons car, and still had to pull fuel, with the same turbo you want to run.
post Nov 4, 2011 - 10:52 AM
well there is your answer, i was just being conservative on my estimate. 460s should be good for quite a bit of boost with out return style fuel systems
Lo-Fi Version Time is now: February 21st, 2025 - 2:05 PM
