> Problem with my 5sfe, White smoke coming out from the hood
post Dec 1, 2011 - 1:11 PM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
Hey guys I'm having a problem with my 95 celica gt 5sfe motor maybe you guys could help me.
While driving ill see white smoke come out from under the hood and from the exhaust. Also while driving I notice that from the air vents white smoke comes out and fogs my windows. What's wrong with my car? Please help! Thanx in advance smile.gif
post Dec 1, 2011 - 1:16 PM
jt1023
Joined Jun 12, '11
From Suffolk County, NY
Sounds like you're burning oil, I would check for oil leaks. See if there are any noticeable wet spots under your hood.
post Dec 1, 2011 - 4:12 PM
you might have a huge exhaust leak too. be careful if you are taking in poisonous gases while driving
post Dec 1, 2011 - 4:19 PM
mkernz22
Joined May 10, '10
From MA
i thought white smoke is coolant and blue smoke is oil?
post Dec 1, 2011 - 4:21 PM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
White smoke is poisonous? Oh **** I thought it was harmless I jus drive when the smoke comes out of the vents...And if I do have an exhaust leak how do I fix it? Do I get my exhaust rewelded?
post Dec 1, 2011 - 4:56 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
If it is white smoke it is probably coolant. Does it smell like gas/oil or does it have a sweet smell to it?
**** Photobucket
post Dec 1, 2011 - 6:07 PM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
Inside the car smells sweet and outside smells like oil and gas
post Dec 1, 2011 - 6:29 PM
thats not a good sign, might have blown your head gasket. are you in Torrance, Southern CA?
post Dec 1, 2011 - 6:47 PM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
Yea I'm in Torrance southern California u r too?
post Dec 1, 2011 - 7:07 PM
6G96GT
Joined Jan 20, '08
From East Coast
Something to do with the cooling anyway. You can check to see if your oil on the dipstick looks like a snotty milkshake after start up or get a head gasket test done for cheap $ at a local garage. You may even want to check in the radiator for oil (black floating spots). Are you getting coolant pouring out of the overflow? Heater core maybe leaking?
post Dec 1, 2011 - 7:15 PM
blown headgasket.
post Dec 2, 2011 - 12:21 AM
trdproven
Joined Aug 2, '05
From Guam
blown hg, or unless you don't drive it very often, white smoke is also from water accumulating from moisture. I thought my gasket was bad too, as I get white smoke since 5 years ago but I did not see any blown headgasket issue. When I replace my exhaust though water drops from the pipe, so it wasn't a blown headgasket, I just drive it once in a blue moon, more like decoration cus I like using trucks on a daily basis.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 2, 2011 - 12:58 AM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
It's my daily driver and I should get a new head gasket or reweld my exhaust and what about the smoke from my air vents what do I do about that? Thanx so much for the help
post Dec 3, 2011 - 12:30 AM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
Is it overheating?
post Dec 3, 2011 - 1:34 AM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
NO it's not overheating
post Dec 3, 2011 - 4:13 AM
trdproven
Joined Aug 2, '05
From Guam
is your coolant or oil look milky or mixed?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 4, 2011 - 9:01 PM
TRD11
Joined Feb 27, '11
From trevorton pa
defiantly head gasket no if and and buts
cant stop wont stop
post Dec 4, 2011 - 9:14 PM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
But I thought if it was the head gasket I would be losing water..and I'm not losing water could it be my piston rings?
post Dec 4, 2011 - 9:46 PM
TRD11
Joined Feb 27, '11
From trevorton pa
well it don't take much for it to smoke ......... your best bet is to drain all the rad fluid ...then start it for one minute and repeat that 2 or 3 times but make sure your car is stone cold before start up each time this will burn out any remaining antifreeze .. if it is the head gasket .. it will not smoke ... but most likely it is the head gasket
white smoke is the antifreeze burning .. oil will be blue
cant stop wont stop
post Dec 5, 2011 - 10:25 AM
have a compression test done. that will tell you all you need to know.
Lo-Fi Version Time is now: December 1st, 2024 - 2:37 AM
