> Is it possible!!
post Jan 18, 2012 - 12:35 PM
Fleshwound
Joined Jan 16, '12
From arkansas
Got a question does anyone know if ist possible to replace the front end of a 98 celica with the front end of a supra! i like the celica except for the circular head lights and i was just wondering if its possible to replace the fenders and front bumper cover etc to a supra front end! thanks guys
post Jan 18, 2012 - 12:58 PM
rave2n
Joined May 29, '09
From Gainesville, FL
http://www.supratraderonline.com/
post Jan 18, 2012 - 1:51 PM
richee3
Joined Jun 29, '08
From Denver
Is it possible? Yes. Is it feasible? Not really. It'll be fully custom fabricated and will be a nightmare to do yourself unless you've done similar conversions. A shop will charge you an arm, both legs, and your firstborn child. Playr158 did the conversion once and his advice is to drop the car off at a shop, cut a huge check, and pick it up later.
The Supra is a larger car than a Celica so in my opinion, the conversion doesn't look good anyway.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 18, 2012 - 2:25 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
It can be done but takes alot of custom work
look into a curren front end. Its mostly a straight swap an itll get rid of the the factory lights
But parts are harder to find
94 st hatch my daily driver
n
post Jan 18, 2012 - 2:27 PM
cheela
Joined Feb 2, '07
From Berlin, WI
curren swap on a cell looks better than a supra swap on one.
post Jan 18, 2012 - 2:28 PM
QUOTE (kurt95gt @ Jan 18, 2012 - 2:25 PM) *
I've done both.
Supra parts are much wider (6") and longer.
so its all custom and requires lots of work...take it to a professional, cut a check.
Curren requires rare OEM parts, you have to (like the supra) cut out the radiator core supports and swap them and then it all bolts together, so its much simplier than surpa.
also use the search button.
post Jan 18, 2012 - 7:47 PM
Fleshwound
Joined Jan 16, '12
From arkansas
thanks guys I may just.end up buying both I found a supra for 6000 its got water damage but I can restore it
post Jan 18, 2012 - 8:42 PM
richee3
Joined Jun 29, '08
From Denver
Do it! If you don't, I will. I'm dead serious.
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: December 4th, 2024 - 9:04 AM
