White Gauge wiring |
Dec 23, 2003 - 7:08 AM |
Enthusiast Joined Dec 21, '03 From Portland, OR Currently Offline Reputation: 0 (0%) |
I just bought some white indiglo gauges for my car to go over the black ones but I was curious as to what to plug into for the power source. Should I use the dimmer or is there something else I should tap into for the switch?
Dec 23, 2003 - 10:37 PM |
YOu can use the dimmer or you can use the light on wire that connects to the stock radio wiring harness, its a yellow wire.
Dec 24, 2003 - 3:48 AM |
Enthusiast Joined Sep 6, '03 From Fairbanks AK Currently Offline Reputation: 0 (0%) |
if you do use the dimmer, as i did, make sure you tap into the 12V constant going to it not the variable comming out.
This post has been edited by van95st: Dec 24, 2003 - 3:48 AM |
Dec 24, 2003 - 11:31 AM |
Isnt the variable the one that does the dimming? So that you can dim them?
Dec 24, 2003 - 1:24 PM |
Enthusiast Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
The gauges come with a dimmer. Tapping the variable side of the cars dimmer will burnup the gauges.
Dec 24, 2003 - 1:44 PM |
10-4
Just wonderin. -------------------- |
Lo-Fi Version | Time is now: January 5th, 2025 - 10:45 PM |
