Dot4 in our car. |
Dot4 in our car. |
Jan 25, 2012 - 10:20 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Has anyone tried Dot4 brake fluid in our car? I heard it was compatible, but is it worth it? Did you notice a difference?
Jan 25, 2012 - 11:07 PM |
you cant mix dot3 and 4 so you'll have to drain the system. refill with dot4 and remove air bubbles. I dont see why you'd need a higher grade of brake fluid. Most cars will never exceed dot3 boil temps unless racecar
Jan 26, 2012 - 12:51 AM |
you cant mix dot3 and 4 so you'll have to drain the system. refill with dot4 and remove air bubbles. I dont see why you'd need a higher grade of brake fluid. Most cars will never exceed dot3 boil temps unless racecar When I said compatible, I meant system compatible not mixable. And I wanted to know cause I might want to get it on the track a little. |
Jan 26, 2012 - 1:21 PM |
Enthusiast Joined Jul 29, '11 From chino, Ca Currently Offline Reputation: 4 (100%) |
yeah it should be compatible dot 3&4 aren't to different in a way just boiling temps are different, if you want to do it the right way you will have to run denatured alcohol through your brake lines then run the dot 4 in after that it takes a long time and its very tedious the hard part is getting all of the bubbles out
Jan 27, 2012 - 3:38 PM |
Enthusiast Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) |
DOT 5 is the stuff you don't wanna mix.
Car Talk - Brake Fluid -------------------- |
Jan 27, 2012 - 6:59 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
You wont notice a difference between dot 3 and 4 in our cars, in any situation.
Jan 27, 2012 - 8:01 PM |
Enthusiast Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
i dont even see how it could in anyway make a difference unless your boiling your brake fluid which i doubt
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Jan 28, 2012 - 5:19 AM |
Enthusiast Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) |
You can mix DOT 3, DOT 4 & DOT 5.1, if you have DOT 3 in your system its fine to top it up with DOT4 or DOT 5.1 as they are all polyethylene Glycol based fluids, DOT 5 is silicon based and should not be mixed ever.
Lo-Fi Version | Time is now: December 4th, 2024 - 12:21 AM |
