3sge coversion to 3sgte ?, want to convert my 3sge to a 3sgte |
Feb 1, 2012 - 12:50 PM |
Enthusiast Joined Feb 1, '12 From england Currently Offline Reputation: 0 (0%) |
hi guys first time posting was wondering if a 3sgte will fit straight into my st202 ?
cheers |
Feb 1, 2012 - 3:19 PM |
Moderator Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) |
There might be some wiring involved but they use the same mounts so yes, it will swap in. You cannot use the AWD transmission without doing an AWD conversion though. Check the stickies in the Engine/Transmission/Maintenance forum- there is loads of information there. Welcome to the site
Feb 2, 2012 - 12:55 PM |
yeaa need to wire in a new ecu n bits n bobs , was gonnna use my transmission so it front wheel drive as i have the gearbox and limited slip diff in it already
cheers |
Feb 2, 2012 - 2:23 PM |
In that case, you're all set The S54 trans is good up to about 300 hp. After that, the E153 is a stronger trans and has longer gears which suit the power better.
Feb 3, 2012 - 1:19 AM |
Enthusiast Joined Jun 7, '11 From so cal Currently Offline Reputation: 0 (0%) |
so basicaly we can use the ge harness and just re-pin the ecu plugs?
Lo-Fi Version | Time is now: December 2nd, 2024 - 5:55 AM |
