Enthusiast Joined Apr 12, '12 From California, Japan, Sometimes Europe Currently Offline Reputation: 0 (0%) ![]() |
I decided rather then reply to each individual question here, it is far easier for me to help some of you out. Please understand I do this for a living, and contribute information
merely at my own free will and ( technically it is my day off. ) Some of what I have seen on here is disturbing, and scary. Not to insult, but I feel bad seeing people who really spend probably a lot of hard earned cash and well un-knowingly pop engines, most of you should get 40,000 to 80,000 miles on a average tuned engine. And about 80 to 300 life hours on a motorsport race engine. There are a number of parameters when one discusses the right approach for forced induction. We have to consider the pre-exist vehicle architecture and potential of the ancilary hardware and mechanical to establish basic parameters. The approach on a factory forced induction application is very different then a vehicle that was not equiped from the factory with a forced-induction system. Fuel System : Typically the in-bound or feed line is one AN size larger then the return line. Even when using the proper injector and fuel pump sizing, a fuel system will not flow adequately unless the hoses that deliver the fuel to the fuel rail are of sufficient size and are routed properly. ( aprox ) most of you will use a - 5 ~to~ -8 AN hose / line. Of course this all depends on the specific set up and ( individual user requirements. ) Depending on how you select your lines you could support 300 ~ 500 + hp. Few here are rocking 700hp machines. Typically there is no need to replace the fuel delivery hoses unless the engine is heavily modified. It is never a good idea route fuel hoses through the interior of a car. Put bluntly, this is a dumb & dangerous thing to do. If applicable or possible, use a delivery tube to make the connection from the pump discharge to the filter in the front of the car. The lines should be rated to withstand at least double the maximum pressure of the EFI system. This is especially true when discussing forced induction applications as fuel pressures in such systems can be much higher then NA or factory applications. For example a engine with moderate boost, with expected fuel pressures at around 65-70 psi range. This will require a line with at least 140-psi rating (most AN hoses exceed this by a large margin). Double Check, Triple Check that the margin exceeds by at least double and consider how much pressure the lines can withstand at extreme tempretures! When deciding on routing of the fuel lines, it is absolutly important that they are protected from road hazards, contact with objects and the exhaust system. The fuel line should NEVER be routed near battery cables. Use clamps to secure AN hose every 8~12 inches, or 24 inches if a rigid tube is used ( Technically speaking I prefer bracing more then 24 inches. ) Often overlooked in EFI installations, the fuel filter must have the capacity, filtering efficiency and burst strength to withstand the pressures of an EFI system. It must be able to flow the amount of fuel that matches the maximum fuel pump output. The filter is always located after the fuel pump, however it does not matter if it is positioned in the front or rear of the vehicle (we prefer to put it toward the front for easy serviceability). high flow fuel filters for high-powered engines are a must, often these have design in mind and are of a high volume, replaceable filter element. It is also important that a pre-filter be mounted to the fuel pick up in the tank. Such filters are designed with high high volume in mind and create very little / mild pressure drop. The use of a pre-filter ensures long fuel pump life and can eliminate low flow conditions caused by debris entering the pump inlet and thus damage. The fuel rail. The fuel rail should be consistent with, or larger than, the hose size. Additional capacity of a large-diameter fuel rail helps to ocillate / dampen the pulsations created by the fuel injectors and ensures even fuel delivery under all conditions. ( Remember to always have injectors secured! ) Boost controller : There are a number of different boost controllers out there on the market. Manual controllers aren't bad, because they tend to keep individuals away from the temptation of ( increasing boost ) to a possibly risky level. All of the units I have used have been reliable. There are a number of different units, electronic or pneumatic you can select. Most high end engine-management systems can actually control both boost / waste-gates. Waste Gate Internal : These are typically common on most factory OEM units, you can identify such units as they are integrated into the turbo-charger-housing itself. Usually smaller turbochargers low to medium pressure applications perfectly fine. External Waste-Gates : External Waste Gates are physically not mounted to the turbo-charger itself. Furthermore these are mounted typically to a cast or tubular constructed turbo-manifold. Depending on the application and mostly on high pressure systems I tend to prefer the external units. You don't ever want to question the units ability to control pressure. Waste Gate Size : This is a generic chart, if I recollect the first chart is what turbosmart recommends. However, in reality there are a number of aspects specific to individual systems. These are helpful for those who might have issues selecting a properly sized waste-gate. big turbo/low boost = bigger wastegate big turbo/high boost = smaller wastegate small turbo/low boost = bigger wastegate small turbo/high boost = smaller wastegate One must consider , the flow of exhaust and the effect on how power is achieved. So, one could technically use a different chart. big turbo/small engine/small power = small wastegate big turbo/big engine/ small power = medium wastegate big turbo/small engine/big power = big wastegate small turbo/small engine/small power = small wastegate small turbo/big engine/any power level = big wastegate " The concept behind this is that the small-esq turbine will attempt to overspin from excess exhaus gas volumes. ( Both charts are generalized slightly ) Atomespheric BOV : Location of blow off valves are very important. The most ideal location is as close as possible to the throttle. ( Especially on units that are non adjustable. ) In some applications, or if installed or placed or adjusted incorrectly you can encounter, poor throttle response, rich or lean Air fuel mixtures. In some application / situations a surge. If venting to atomespher then I prefer at least a tunable / adjustable BOV. Still as close as possible to the throttle. Re-Circulating System : Most highend modern machines, use such systems. Again location is still as close as possible to the throttle, and thus re-circulated / re-introduced into the stream. Both boost is not wasted. Regards, Mick - ( I'll address intercoolers and so on later ) Sorry for the lag in editorial of my own posting. This post has been edited by Micky_lovescelica_noise: Apr 14, 2012 - 5:09 PM |
Where did you get your Engineering degree from?
Enthusiast ![]() ![]() Joined Dec 30, '09 From Wilmington, NC Currently Offline Reputation: 1 (100%) ![]() |
^x 2, no offense guy, but you've just listed a bunch of theoretical responses in the past few threads. People are looking for members to chime in who have done something similar (or perhaps different) and how it worked out. You're wasting your free time with all that typing. Just my 2 cents.
This post has been edited by al94st: Apr 14, 2012 - 4:28 PM |
^x 2, no offense guy, but you've just listed a bunch of theoretical responses in the past few threads. People are looking for members to chime in who have done something similar (or perhaps different) and how it worked out. You're wasting your free time with all that typing. Just my 2 cents. Al or Al94ST not sure if your first name is Al, but ah thanks for the two cents. I would't say that I was totally out of line, I can understand your view / perspective. Most people were kind of vague at very best. They want the Unicorn answer, or end point. Yet many don't think of the variables. There is a start, steps to a middle, thus more steps to a final result. If one wanted to give a definative answer, one might want to inquire before saying X, Y, Z. I've no hard feelings. ![]() This post has been edited by Micky_lovescelica_noise: Apr 18, 2012 - 11:29 AM |
![]() Enthusiast ![]() ![]() Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) ![]() |
Hi,
Al, if you saw a guy who is hungry you can give him a fish and he will be feed for a day, but you can also learn him fishing and he will be feed the whole live it is great if you have one that helps you but nothing is won if you do not understand it, theoretically answers have the sense of understanding and further more to solve problems by yourself Micky did a great job and i'am sure the basic knowledge in here will give many people support by there projects ![]() greetz This post has been edited by Sunny: Apr 18, 2012 - 3:09 PM -------------------- |
Hi, Al, if you saw a guy who is hungry you can give him a fish and he will be feed for a day, but you can also learn him fishind and he will be feed the whole live it is great if you have one that helps you but nothing is won if you do not understand it, theoretically answers have the sense of understanding and further more to solve problems by yourself Micky did a great job and i'am sure the basic knowledge in here will give many people support by there projects ![]() greetz Sunny, Thanks for the friendly words! Cheers and have a great week! Best regards, Mick- |
I just wanted to add, the information here is to give an over-view of components and information as more so for basic guidlines.
Tuning is specific to the configuration and requirements of the user / vehicle application and or maybe with in laws or race regulations if applicable. Please understand that I probably won't be on here that often. I merely had a bit of free time. Came on and decided, cool I'll contribute. As I have time I'll up date / edit. Often times theories and parameters change with the application and system requirements or desired goals. Enjoy the week! Regards, Mick - |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) ![]() |
No offense but the way you see yourself above everybody else... I thought you would add some useful/hard to find info. I can find this on google if I wanted to. "What is a BOV?"
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) ![]() |
^ Guy, the fact of the matter is that this man took the time to write up some good knowledge, it is detailed. On a site like this, no less...**** doesn't come around much. Stop complaining.
-------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
^ Guy, the fact of the matter is that this man took the time to write up some good knowledge, it is detailed. On a site like this, no less...**** doesn't come around much. Stop complaining. Not complaining. He just seems to believe he is superior to everybody else, yet he's sharing COMMON knowledge. If this info hasn't been posted before it's because it's been posted everywhere else many, many times, and it is just waiting to be searched. -------------------- 1993 Celica GT Coupe - sold
^ I understand, I read your post. I'm just not seeing (not in this thread, at least) where content posted by the OP is akin to chest-thumping. Just sharing knowledge...and there's something wrong with that?
This post has been edited by SwissFerdi: Apr 19, 2012 - 8:27 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
^ I understand, I read your post. I'm just not seeing (not in this thread, at least) where content posted by the OP is akin to chest-thumping. Just sharing knowledge...and there's something wrong with that? Check all of his other posts. -------------------- 1993 Celica GT Coupe - sold
Okay, just read them all. Still not seeing it, so...sorry. I'll see myself out of this discussion now, take care.
'93 MX-5 LE |
Guess it's a matter of perspective.
Lo-Fi Version | Time is now: February 21st, 2025 - 7:29 AM |
