> St205 code 54 error
post Apr 24, 2012 - 8:22 PM
belanger33
Joined Feb 10, '11
From Montreal,QC
Hi everyone,
I run a relatively stock ST185 RC and i swapped the electronics(Map, igniter, injectors, and ECU) for the MAP processed ST205 setup. Now as you may know, i ran into code 54 error because of the intercooler pump error....I tried the relay method with the resistors and grounded the LEV at the ECU too but i still get the code while driving...Anyone one has other methods or suggestions to cure that error code please....
Thanks for the help,
Mathieu
post Apr 25, 2012 - 3:30 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (belanger33 @ Apr 24, 2012 - 9:22 PM) *
Hi everyone,
Mathieu
Make sure the IC if filled to top with coolant. All I had to do with mine was add just a little coolant and the code disappeared.
post Apr 25, 2012 - 5:00 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE (dudeofchaos @ Apr 25, 2012 - 10:30 AM) *
Exactly. Also will help to reset all saved codes by disconnecting battery or pulling the ECU fuse for 30 seconds.
Lo-Fi Version Time is now: February 22nd, 2025 - 3:24 PM
