> Ticking
post Apr 26, 2012 - 6:09 PM
pipwud
Joined Apr 10, '12
From phoenix, arizona
I have been eliminating various noises from my car for sometime. Up until now, all issues have been diagnosed and cured. I am now left with a strange ticking noise coming from the area around the throttle body/intake manifold/transmission. I am not definite on which it could be.
The ticking is consistent at idle. When I give it throttle, the ticking accelerates, as expected. If I give it too much throttle to quick, the engine bogs down, but continues to run and levels out.
More importantly, when the clutch is disengaged (my foot is on the pedal) the noise stops. When it is engaged (foot off the pedal) the noise resumes.
I can't come to a conclusion. Please help.
If it matters, I just installed a new clutch, but the noise has been there since before.
This post has been edited by pipwud: Apr 26, 2012 - 6:33 PM
post Apr 26, 2012 - 7:21 PM
richee3
Joined Jun 29, '08
From Denver
Did you just replace the throw out bearing as well?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 26, 2012 - 7:28 PM
pipwud
Joined Apr 10, '12
QUOTE (richee3 @ Apr 26, 2012 - 8:21 PM) *
I replaced the flywheel and ring gear, friction disc, pressure plate and input shaft bearing.
post Apr 27, 2012 - 3:21 PM
pipwud
Joined Apr 10, '12
On a related issue, my car acted out today. For a moment, after I shift up, when I had already engaged the clutch and was givin it throttle, the car would rev up like it was in neutral. There was no momentum gain, the rpm would just shoot up. I shift up again and the problem still occurred. After shutting her down and starting it, the problem subsided.
post Apr 27, 2012 - 5:09 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
Its your throw out bearing, you need to replace it.
The throw out bearing presses on the prongs of the pressure plate disengaging the clutch, I would also check you clutch fork for proper free play.
post Apr 27, 2012 - 5:17 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
BOMB!
エキサイティングカーレーシングチーム!
post Apr 27, 2012 - 7:54 PM
pipwud
Joined Apr 10, '12
QUOTE (Tigawoods @ Apr 27, 2012 - 5:17 PM) *
BOMB!
That's good.
post Apr 27, 2012 - 8:16 PM
pipwud
Joined Apr 10, '12
QUOTE (hatchy_gt-s @ Apr 27, 2012 - 5:09 PM) *
Thank you
post Apr 27, 2012 - 11:22 PM
pipwud
Joined Apr 10, '12
Can you direct me to where I can get a throw out bearing? Or any celica parts for that matter, please.
post May 1, 2012 - 5:03 PM
pipwud
Joined Apr 10, '12
QUOTE (hatchy_gt-s @ Apr 27, 2012 - 6:09 PM) *
Is there a way to post pictures directly off my phone? Is like to show you what I replaced. I have a picture of my tranny from when I took it off with the new parts on it.
post May 1, 2012 - 5:16 PM
richee3
Joined Jun 29, '08
From Denver
partznet.com, lithiatoyotaparts.com, toyotapartseast.com are all good places.
1998 Celica GT-
BEAMS Swapped.
post May 1, 2012 - 10:12 PM
pipwud
Joined Apr 10, '12
QUOTE (richee3 @ May 1, 2012 - 6:16 PM) *
I've been to multiple sites n I've not come across the throw out bearing.
post May 2, 2012 - 2:03 AM
pipwud
Joined Apr 10, '12
It was the clutch pressure bearing I replaced. That n the input shaft bearing are all I found.
post May 2, 2012 - 6:14 AM
richee3
Joined Jun 29, '08
From Denver
Release bearing, input shaft bearing, throw out bearing. To-may-to, to-mah-to. Same thing by a different name. As long as its the bearing that sits in the clutch fork, it's the same one.
1998 Celica GT-
BEAMS Swapped.
post May 3, 2012 - 11:26 AM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
Actually the release bearing and throw out bearing are the same, BUT the input shaft bearing is something totally different.
post May 6, 2012 - 5:12 AM
pipwud
Joined Apr 10, '12
QUOTE (richee3 @ May 2, 2012 - 6:14 AM) *
So which should I replace.
Lo-Fi Version Time is now: December 4th, 2024 - 12:58 PM
