97 Toyota Celica GT electrical problems |
Apr 30, 2012 - 8:40 PM |
Enthusiast Joined Dec 10, '08 From Crescent City Currently Offline Reputation: 0 (0%) |
Hi there,
I need help with my car. My power windows, gauge light, and the interior accessories doesn't work. The back light don't work but when i step on breaks the break light works. The fan doesn't come on so the radiator gets hot. I bought a new alternator but it didn't make any changes. Any suggestions? |
Apr 30, 2012 - 9:34 PM |
Enthusiast Joined Apr 22, '12 From Central NY Currently Offline Reputation: 5 (100%) |
Check all your fuses and relays ... ALWAYS do this with electrical before you go buy parts.
-------------------- 99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo 2010 Acura RDX Turbo w/ Technology Package 68 Impala SS Convertable |
Apr 30, 2012 - 9:44 PM |
^That. Can get a fuse checker for cheap. Most fuse multi-packs come with one these days anyway. If you don't have one and have a multi-meter, can use that to check for continuity on the fuses. If you don't have a multi-meter, you'll need one anyway for checking electrical components.
Apr 30, 2012 - 9:51 PM |
Remember there are 2 fuse panels. Relays you can check easily. Listen for a click when you activate it. If it doesn't click, it's most likely bad. If it clicks, well that doesn't mean it's necessarily good; it might not be making a connection. Swap one in from another circuit that you KNOW works.
Jun 7, 2012 - 9:37 PM |
I already checked all fuses. Nothing's wrong with it. Do you guys know where the circut breaker is located at?
Jun 7, 2012 - 9:41 PM |
Jun 8, 2012 - 12:03 AM |
Enthusiast Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
Check your alt fuse under the hood again
Those are all the same problems i had when my alt fuse blew -------------------- 95 gt coupe, v6 swap weekend toy
99 gt hatch beams swapped wife's 94 st hatch my daily driver http://www.6gc.net/forums/index.php?showtopic=82235 n |
Jun 8, 2012 - 2:19 AM |
Enthusiast Joined Apr 6, '12 From somewhere Currently Offline Reputation: 0 (0%) |
^^happened to me before 2 i couldn't even move the auto shifter. i remember it was pain in the ass to change it.
Jun 8, 2012 - 8:07 AM |
Enthusiast Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
On the passenger side of the radiator, near the botttom and right next to the radiator hose, there is a fan switch screwed into the radiator. It looks like a temperature sensor. Unplug it. If the fans and relays are good the fans will kick on and run nonstop while this wire is unplugged
Lo-Fi Version | Time is now: November 30th, 2024 - 6:45 AM |
