full 1995 toyota celica 7afe dohc 1.8l engine gasket set stock, for sale |
May 11, 2012 - 1:10 AM |
Enthusiast Joined Mar 6, '11 From Canoga Park Currently Offline Reputation: 0 (0%) |
head gasket engine set all the gaskets needed for doing a big repair like a head gasket job for 1995 toyota celica 1.8l 7afe dohc engine $60.00 obo
still new in the packaging unopened David 818 272 6430 Canoga park,ca 91306 west San Fernando valley area This post has been edited by dnewton: May 11, 2012 - 1:11 AM |
May 11, 2012 - 1:13 AM |
head gasket engine set all the gaskets needed for doing a big repair like a head gasket job for 1995 toyota celica 1.8l 7afe dohc engine $60.00 obo still new in the packaging unopened will work on all celicas with the 7afe engine 1994,1995,1996,1997 years I think just check ur under the hood catalyst info sticker to check. David 818 272 6430 Canoga park,ca 91306 west San Fernando valley area |
Oct 7, 2014 - 6:16 AM |
Enthusiast Joined Aug 16, '11 From california Currently Offline Reputation: 0 (0%) |
head gasket engine set all the gaskets needed for doing a big repair like a head gasket job for 1995 toyota celica 1.8l 7afe dohc engine $60.00 obo still new in the packaging unopened David 818 272 6430 Canoga park,ca 91306 west San Fernando valley area When did the 7afe go dohc? |
Oct 7, 2014 - 9:47 AM |
Enthusiast Joined May 10, '14 From Tulsa, OK Currently Offline Reputation: 5 (100%) |
I have a 1996 and it is DOHC.
Oct 7, 2014 - 9:53 AM |
Oct 12, 2014 - 10:26 PM |
Enthusiast Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
I have a 1996 and it is DOHC. No wayy wtf?!? And they say the 7afe wasnt made for performance ... Well **** , I feel like I'm totally missing out w my sohc 7afe st. I send need to find one and turbo that bitch! This changes everything All 7afe s are DOHC, there's one master can gear driven by the belt and then under the valve cover theyre connected. I might not be using the correct terminology but they are ALL DOHC to my best knowledge. -------------------- For Sale:OEM tail lights - make offer
Oct 12, 2014 - 10:54 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I have a 1996 and it is DOHC. No wayy wtf?!? And they say the 7afe wasnt made for performance ... Well **** , I feel like I'm totally missing out w my sohc 7afe st. I send need to find one and turbo that bitch! This changes everything All 7afe s are DOHC, there's one master can gear driven by the belt and then under the valve cover theyre connected. I might not be using the correct terminology but they are ALL DOHC to my best knowledge. They're definitely all DOHC. Just one master cam that one can see from the outside of the motor connected to the other cam under the valve cover. -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Oct 13, 2014 - 3:20 AM |
Enthusiast Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) |
It is a DOHC motor but 7A employed a "slave cam system", the camshafts being geared together and driven off one camshaft's sprocket unlike say the 4A-GE both camshaft sprockets are rotated by the timing belt. The reason why some might view the 7A as a SOHC is that it only uses a single cam to run both. However as far as performance, adjustments in timing your intake and exhaust valves are far easier with a twincam setup as you can use the cam gears to adjust with without having to tear down the head of the engine. Sorry dnewton for using your FS thread to explain this, best of luck on the sale, I'd take it but not on the lookout for an engine rebuild just yet.
This post has been edited by igpx12: Oct 13, 2014 - 3:22 AM -------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
Lo-Fi Version | Time is now: December 3rd, 2024 - 5:37 AM |
